Service air bag light?
biggator64
I have a 05 Yukon and a 03 Tahoe both have service airbag light on? the Yukon light came on one day while driving at about the same time that the rear drivers window stopped working, I replaced the window motor and that works but still have the airbag light. So I am not sure where to start but I would like to fix these with out setting off the airbag in either one.
Any help would be great where should I start??
treehan77
TYF Fiend
Crestview, FL
My passenger side went out, then the driver side 4 months later. Easy to replace, not too expensive ($60 or so on amazon). A code scanner will tell you which one it is
Yep, I've scanned a couple trucks and that was their problem and I suspect the same for Andy's Tahoe whenever we get to check his.
B
biggator64
well thank you guys for the replies, I will have it scanned later today last time I had the Yukon scanned nothing came up on it, but this time I will take it to auto zone at least I have a point to start with.
These will be BCM or Chassis codes. Basic readers can't see these.
treehan77
TYF Fiend
Crestview, FL
My $15 eBay reader read mine with dashcommand, I’m sure torque pro can read it as well
From a reply to my post on this:
B0100 as "Electronic Front End Sensor 1." From reviewing online I determined this code to be the front left or drivers side sensor. Apparently code B0103 isfor the front right or passenger impact sensor.Idecided to go with the Dorm
Drewphil
