Seat heater?
When I do a remote start and it is cold my seat heater does not turn on. Does anyone else's not turn on during the remote start?
I have my preferences that says it should but it is not doing it.
whoseanthony
Arkansas
The interior temp of the vehicle has to hit a certain threshold before the seat heaters/ac kick on. Unfortunately you cannot change or determine that threshold.
B
That seems very strange. When it's cold why didn't they design it for the heaters/ ac to come on the seats?
GMT800 2005 Tahoe Z71
Navy Supporting Member
You would need to ask an engineer about that. They just design them. They don't work on them. I personally wouldn't want them to come on till I turned them on after getting in vehicle. I don't want something heating up inside my rig unless I turn it on.
Reels
Senior Member
This is on my list of issues to check my first oil change. Even at 5 degrees, the heat and heated seats are not coming on with auto start, even though the auto setting is on the system.
smittydog
mine doesn't either. It was 17 degrees this am...no auto heated seat when remote starting vehicle.
(my Jeep GC would turn on heated seats and steering wheel when 32 degrees and below. Also, in summer, it would turn on the cooling feature on the seats)
Steve
ScottV503
PDX
I thought I had the same issue but in the manual it says the indicator lights on the seat heat button will not turn on during a remote start even though the seat heat will be on. And if you dig further in the manual, it says the performance of an unoccupied seat will be reduced. With that, all I can say is that I can (barely) feel the seat heat when I enter the vehicle after a remote start, but it is working.
ebdesant
Steve
My auto start heated seats arent working either as well as my heated seats in general. Lights on switches light up but no heat. Gotta love GM quality
zolt11
Mine dont seem to be going on either. I think 6 degrees should meet the temp threshold...
JasonDenali15
Buffalo, NY
Mine doesn't work either on the remote start. -1 this morning. I have it set properly in the settings. Also, it takes forever to warm up once I turn it on manually. You guys too? My 2004 Denali seats warmed up instantly.
SFM Doug
certain manufacturers disable the heated seats on with remote start because of the risk of fires. stupid as that sounds but i had 2 jeep grand cherokees and one was disabled and one was not.
rossida
