2019 Tahoe B0413
BigMountains
Hello, I have a 2019 Tahoe that only throws warm air. The compressor has been replaced, but the problem did not change. Revving the engine does not change anything. I have noticed that the cooling fans run in low speeds for a few seconds and then they turn off. The only time the A/C is cool is when I use a scanner.
Reading the codes, the only code I got was a B0413 - Main Temperature Actuator Circuit Fault. I have already changed the actuator and tried calibrating it, but the code still appears and the status of the new actuator says it failed the calibration.
Any ideas would be very helpful.
LsHart
Senior Member
Where did u get the part from? U can power probe the ac relay and command the compressor on and see if it cools. Possibly the high pressure sensor is bad? Or not enough freon
B
BigMountains
I don't know where the compressor was from, but it was changed. The high pressure sensor was giving me around 1.6 volts and around 165 psi.
B
BigMountains
I replaced the compressor and the high pressure sensor and the truck is cooling now, but out of nowhere, it gets hot for a second a then it cools down again.
One thing I forgot to mention is that the code, B0413 still shows up, but when with the old blend door actuator, the code was B0413-05. With the new one, it is B0413-61.
mudrunnerz
