Seafoam
acainindy
Knoxville TN
I ran a can thru a tank of gas last week and added a can to my crankcase during an oil change. I didn't get all the smoke that everyone says you get from the engine add but we will see if it helps. Advance auto had it on sale 2 for 1
dropmech
Puddle Pirate
Coral Springs
Depending on how many miles/how old your truck is, will be a factor in how much crap you get removed from there. I have an 06 and got a small amount but nothing like you see on youtube with these huge clouds. As for the OP, I'm not sure there is anyone here that is against it. Seafoam has been around much longer than most of the members on this board. It's formulated to not mess up your sensors or cause internal damage. Now if you get some sort of fault code as a result, it's probably because you dislodged a piece of crap from somewhere in your system and it got caught up on a sensor or blocked it. To that I say run it through a second time.
04Hoe
If you use the product correctly, it works great. Must let the vaccum line suck up half the can, shut engine off and leave it sit for 15-20 minutes, then go for a ride.
Will be a huge plume of smoke for a few blocks.
highrollin113
highrollin113
Undercover
Edmonton, Alberta, Canada
well i am getting more and more confused the more i read and see about this lol, so if i vaccuum up half the can and drive and put other half in fuel tank, am i done? what is this talk of oil change
HokieHigh
Seattle Wa
you do it about 300 to 500 miles before an oil change, then when you change the oil all the crap that the seafoam cleans up will come out with the oil change.
puckhead
CO
Seems easy enough. Where is this vacuum line at? Anyone have any pics?
tybardy
everyone needs a Hoe
Gilbert Arizona
stuff is GREAT! I have put it in my gas, crank case, and Vac line... only complaint I have heard that makes sense is the possible build up it creates on the pluggs. I did not have a problem with that though.
yukonjacks
A Vegitative State
The Confluence
I use it everytime I do an oil change, I also keep a spreay bottl;e with it and clean my TB inside at every oil change.
Redhoe01
The BDG
Forney, TX
So adding this to my tank will clean the injectors? In the oil will clean the crank case? What does it clean if you use the vacuum line at the rear of the engine? Manifold maybe?
cam3439
Yes. Yes, crankcase and anywhere the oil gets to (including the upper valve train). Try to put it into a vacuum line that will allow the seafoam to be evenly distributed like a vacuum line that is in the middle of the manifold (like the PCV valve line). And it should clean the inside of the intake manifold, intake ports, and intake valves. You should be good.
highrollin113
highrollin113
Undercover
DESIGN
North Texas
It only cleans the injectors if you put it in the gas tank. If you suck it through vacuum line then it cleans the carbon buildup in the intake manifold.
DenaliAK
Colder than you
Alaska
I wish someone else on here was in Alaska...I need someone to show me what the hell the vac line is....
I can, however, find my own gas tank.
:D
Tribalbreak
WARminster PA
just my 2cents, i seafoamed my 03 Denali that had no previous problems, within 2 days i was replacing o2 sensors... haven't done it since... tried it on my wife's old 97 Honda prelude... same thing replacing o2 sensors... so for me i wont put that stuff through my vehicles anymore... i always herd good things... but experienced nothing but problems...
DenaliAK
Colder than you
Alaska
Hmm.
If it ain't broke, don't fix it, right?
I think I'll hold off for now. The last thing I need is car problems.
dizhai
