RPO Codes
Ron C
Los Alamos, NM
Hello,
I found a list with RPO codes, don't know how accurate it is but sounds 'legit' from what I can tell.
Here is the list:
http://d354nuoz4t18d4.cloudfront.ne...89e6/images/custom/rpoCodes.pdf?cb=1497380755
Here's what's in mine:
AG1: ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER
AG2: ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER
AJ1: GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW)
AJ7: RESTRAINT SYSTEM FRT SEAT, INFLATABLE, DRIVER AND PASSENGER, FRT & SIDE
AL0: SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
AM1: CONTROL SEAT, MANUAL LUMBAR, DRIVER
AM8: SEAT RR BENCH, SPLIT STOWABLE
AP8: LOCK CONTROL,REMOTE ENTRY,EXTENDED RANGE
ARL: PLANT CODE-ARLINGTON TX, CPC
ASF: SEAT DRIVER,AIR,LOW BACK,VINYL,BOSTROM 910
ATD: SEAT THIRD ROW DELETE
AU3: LOCK,SIDE DOOR,ELECTRIC
AXP: VIN IDENT POSITION, MULTI- PURPOSE VEHICLE
A31: 2011 OEM ENGINE PHYSICAL ID A31 & PRODUCTION NUMBER 94672450
A95: SEAT,FRONT BUCKET,DRIVER,PASSENGER,HIGH BACK RECLINING
BG9: COVERING,FLOOR(RUBBER)
BVE: STEPS RUNNINGBOARD, SIDE
CJ3: AIR CONDITIONER,FRONT,MANUAL TEMPERATURE CONTROL,AUXILIARY TEMPERATURE CONTROL
C25: WIPER SYSTEM,REAR WINDOW(EXPORT,CANADIAN)
C36: HEATER,AUXILIARY
C49: DEFOGGER,REAR WINDOW,ELECTRIC
C6A: GVW RATING(7300 LBS)
C69: AIR CONDITIONER,RR AUX
DH6: MIRROR,INSIDE,VISOR VANITY,RH AND LH(ILLUM)
DK8: CONSOLE ROOF INTERIOR, DELUXE
DL8: MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC,DEFOG
EF7: COUNTRY UNITED STATES OF AMERICA (USA)
E2C: ??
E52: BODY EQUIPTMENT ONE PIECE LIFT GATE WITH LIFT GLASS BOD
FHS: VEHICLE FUEL GASOLINE E85
FLT: ??
GAM: VEHICLE GOVT(G.S.A.)
GU6: AXLE,REAR,3.42 RATIO
G63: PROVISIONS LUGGAGE CARRIER, ROOF
JD9: BRAKE VAC POWER, 17' DISC/DISC, W/VSES, 7700 LBS
JF4: PEDALS ADJUSTABLE, POWER
JL1: CONTROL,INTEGRATED TRAILER BRAKE
JL4: CONTROL ACTIVE BRAKE
KC4: COOLING SYSTEM,ENGINE OIL
KNP: COOLING SYSTEM,TRANSMISSION,HEAVY DUTY
KW1: GENERATOR,160 AMP
K34: CRUISE CONTROL,AUTOMATIC,ELECTRONIC
K5L: EQUIPMENT ENHANCED COOLING PACKAGE
LMG: ENGINE FLEXIBLE FUEL, (GAS/ALC), 8 CYL, 5.3L, SFI, V8 OHV, CYL DEACTIVATION, IRON, GM
MYC: TRANSMISSION AUTO 6 SPD, HMD, 6L-80
NC7: EMISSION SYSTEM,FEDERAL OVERRIDE
NE1: CERTIFICATION EMISSION, GEOGRAPHICALLY RESTRICTED REGISTRATION FOR VEHICLES UP TO 14, 000 LBS GVW (USE 2
NK5: STEERING WHEEL(STANDARD)(EXPORT)
NQH: TRANSFER CASE ACTIVE, TWO SPEED, PUSH BUTTON CONTROL, ALUM
NU5: EMISSION SYSTEM CALIFORNIA, BIN 4
NX7: WHEEL 17 X 7.5, STEEL
NZZ: PACKAGE,OFF ROAD SKID PLATE,SPORT
NZ4: WHEEL SPARE FULL SIZE, 17' STEEL
QGI: TIRE ALL P265/70R17-113S BW R/PE ST TL AL2 (PAFE)
R60: PERFORMANCE PACKAGE 60TH ANNIVERSARY 427 CONVERTIBLE
R9N: ??
R9R: ??
R9Z: ??
SAF: LOCK SPARE TIRE, HOIST SHAFT
TL1: GRILLE,SPECIAL
T74: HEADLAMPS CONTROL AUTOMATIC, DELAY
UD7: SENSOR INDICATOR NEAR OBSTACLE DETECTION/REAR PARKING ASSIST
UE0: COMMUNICATION SYSTEM VEHICLE, G.P.S.---NOT INSTALLED
UJM: TIRE PRESS INDICATOR MANUAL LEARN
UQ3: SPEAKER SYSTEM,PERFORMANCE ENHANCED AUDIO
US8: SPEAKER,REAR COMPARTMENT
U2J: DIGITAL AUDIO SYSTEM S-BAND 'NOT INSTALLED'
U84: ANTENNA BODY SIDE WINDOW, RADIO
VGD: FASCIA FRT, CUSTOM, BODY COLOR
VGE: FASCIA RR, CUSTOM, BODY COLOR
VK3: LICENSE PLATE,FRONT MOUNTING PACKAGE
VR4: TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM)
VT7: OWNERS MANUAL ENGLISH LANGUAGE
V76: HOOK,FRONT TOW
V8D: VEHICLE STATEMENT US
WV9: PACKAGE,VALUE LEADER
XL7: FREQUENCIES RATING 315 MHZ
X88: CONVERSION CHEVROLET / MARKET BRAND CHEVROLET
YD3: AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE
YD5: SPRING,FRONT(BASE EQUIPMENT)
YD6: SPRING,REAR(BASE EQUIPMENT)
YE9: CONVENIENCE PKG COMFORT & DECOR LEVEL #3
YK6: ??
ZRS: TIRE SPARE P265/70R17-113S
ZW7: CHASSIS PACKAGE,PREMIUM SMOOTH RIDE
ZY1: COLOR COMBINATION SOLID
Z82: TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH)
1FL: PACKAGE FL OPTION 1
1SZ: PACKAGE OPTION-
19G: TRIM COMBINATION,CLOTH,BLACK
191: TRIM COMBINATION LEATHER, JET BLACK (L1)
5T5: SEAT OVERRIDE (SEO)
50U: EXTERIOR COLOR ,PRIMARY,OLYMPIC WHITE (??)
6PB: COMPONENT FRT LH COMPTR SEL SUSP(6PB)
7PB: COMPONENT FRT RH COMPTR SEL SUSP(7PB)
9N5: FLOOR CONSOLE,FRONT(DELETE)
Ron C
Ron C
Los Alamos, NM
Click on your avatar in the tool bar, click on CONVERSATIONS, click the START A CONVERSATION button.
I found a link in INBOX that does the same thing? (I hope)
I saw two member discuss installing a center console (IlikeEggs and crashtestdummy) and was going to PM them
jkssv08tahoe
Here is what I got for my 2008. Does anyone have the blank ones? I'm missing 11 codes
2008 Chevy Tahoe RPO codes
AG1--ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER
AG2--ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER
AJ1--GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW)
AL0--SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
AMF--LOCK CONTROL ADDITIONAL, PROGRAMMABLE, REMOTE ENTRY, MULTIPLE UNITS
AM1--CONTROL SEAT, MANUAL LUMBAR, DRIVER
AM8--SEAT RR BENCH, SPLIT STOWABLE
AP8--LOCK CONTROL,REMOTE ENTRY,EXTENDED RANGE
ARL--PLANT CODE-ARLINGTON TX, CPC
AU3--LOCK,SIDE DOOR,ELECTRIC
AXP--VIN IDENT POSITION, MULTI- PURPOSE VEHICLE
A31--WINDOW,POWER OPERATED,ALL DOORS
A95--SEAT,FRONT BUCKET,DRIVER,PASSENGER,HIGH BACK RECLINING
BD2--ORNAMENTATION,EXTERIOR(DELETE)(DELETES 'TAHOE' NAMEPLATE)
BG9--COVERING,FLOOR(RUBBER)
BVE--STEPS RUNNINGBOARD, SIDE
CJ3--AIR CONDITIONER,FRONT,MANUAL TEMPERATURE CONTROL,AUXILIARY TEMPERATURE CONTRO
C25--WIPER SYSTEM,REAR WINDOW
C36--HEATER,AUXILIARY
C49--DEFOGGER,REAR WINDOW,ELECTRIC
C6A--GVW RATING(7300 LBS)
C69--AIR CONDITIONER,RR AUX
DF5--MIRROR,INSIDE,REARVIEW,LT SENSITIVE,COMPASS,O/S TEMP DISPLAY
DH6--MIRROR,INSIDE,VISOR VANITY,RH AND LH(ILLUM)
DK8--CONSOLE ROOF INTERIOR, DELUXE
DL8--MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC,DEFOG
E2C--
E52--BODY EQUIPTMENT ONE PIECE LIFT GATE WITH LIFT GLASS BOD
FLT--
GT4--AXLE,REAR,3.73 RATIO
G80--AXLE,REAR,POSITRACTION,LIMITED SLIP
JD9--BRAKE VAC POWER, 17' DISC/DISC, W/VSES, 7700 LBS
JL4--CONTROL ACTIVE BRAKE
KNP--COOLING SYSTEM,TRANSMISSION,HEAVY DUTY
KW1--GENERATOR,160 AMP
K34--CRUISE CONTROL,AUTOMATIC,ELECTRONIC
K47--AIR CLEANER HIGH CAPACITY
LMG--ENGINE FLEXIBLE FUEL, (GAS/ALC), 8 CYL, 5.3L, SFI, V8 OHV, CYL DEACTIVATION, IRON, GM
M30--TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC
NE1--CERTIFICATION EMISSION, GEOGRAPHICALLY RESTRICTED REGISTRATION FOR VEHICLES UP TO 14, 000 LBS GVW
NK5--STEERING WHEEL(STANDARD)
NQH--TRANSFER CASE ACTIVE, TWO SPEED, PUSH BUTTON CONTROL, ALUM
NU5--EMISSION SYSTEM CALIFORNIA, BIN 4
NX7--WHEEL 17 X 7.5, STEEL
NZ4--WHEEL SPARE FULL SIZE, 17' STEEL
QJP--TIRE ALL P265/70R17-113S BW R/PE ST TL OOR
R6D--
R6K--
R9N--
R9Z--
SAF--LOCK SPARE TIRE, HOIST SHAFT
TFD--
TGK--SPECIAL PAINT SOLID, USED FOR ORDERING PURPOSES.
TL1--GRILLE,SPECIAL
T74--HEADLAMPS CONTROL AUTOMATIC, DELAY
UE0--COMMUNICATION SYSTEM VEHICLE, G.P.S.---NOT INSTALLED
UJ6--INDICATOR,LOW TIRE PRESS
UN9--RADIO SUPPRESSION EQUIPMENT
UQ3--SPEAKER SYSTEM,PERFORMANCE ENHANCED AUDIO
US8--RADIO AM/FM STEREO, SEEK/SCAN, CD, AUTO TONE, CLOCK ETR, MP3, RDS
UT7--PROVISIONS, AUXILLARY ELECTRICAL SYSTEM GROUND
U2J--DIGITAL AUDIO SYSTEM S-BAND 'NOT INSTALLED'
U84--ANTENNA BODY SIDE WINDOW, RADIO
VGD--FASCIA FRT, CUSTOM, BODY COLOR
VGE--FASCIA RR, CUSTOM, BODY COLOR
VH9--ENVELOPE,OWNER INFORMATION MANUAL
VK3--LICENSE PLATE,FRONT MOUNTING PACKAGE
VPV--
VQ2--
VR4--TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM)
VT7--OWNERS MANUAL ENGLISH LANGUAGE
VXS--
V73--VEHICLE STATEMENT - US/CANADA
V76--HOOK,FRONT TOW
WX7--WIRING PROVISIONS,SEPARATE FUSING
X88--CONVERSION CHEVROLET
YD3--AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE
YD5--SPRING,FRONT(BASE EQUIPMENT)
YD6--SPRING,REAR(BASE EQUIPMENT)
YE9--CONVENIENCE PKG COMFORT & DECOR LEVEL #3
YK6--
ZRS--TIRE SPARE P265/70R17-113S
ZW7--CHASSIS PACKAGE,PREMIUM SMOOTH RIDE
Z82--TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH)
01U--EXTERIOR COLOR,PRIMARY,SPECIAL OVERRIDE
1FL--PACKAGE FL OPTION 1
1SZ--PACKAGE OPTION
19D--TRIM COMBINATION,CLOTH,BLACK
19I--INTERIOR TRIM,BLACK
5T5--SEAT OVERRIDE (SEO)
5W4--VEHICLE SPECIAL SERVICE, MUNICIPAL
6A6--BATTERY 730 CCA(DUAL)(SEO)
6J1--WIRING,IGNITION AND MAIN POWER SUPPLY
6J3--WIRING-HEADLIGHT FLASHER, GRILLE LIGHTS & SPEAKERS
6J4--WIRING,HORN/SIREN CIRCUIT
6J7--FLASHER HEADLAMP
6PB--COMPONENT FRT LH COMPTR SEL SUSP(6PB)
7PB--COMPONENT FRT RH COMPTR SEL SUSP(7PB)
7X6--SPOTLAMP-LEFT HAND HALOGEN PILLAR MOUNTED
9N5--COMPONENT RR RH COMPUTER SEL SUSP (9NS)
9V5--COLOR COMBINATION,WOODLAND GREEN
DrSpork
