Roof Rack--Cross Rail Removal--
BobMc
Yes--I have searched--
I understand that there are a total of four Torx that must be removed from the aft end caps on an 09 Tahoe.
The question is--
After those Torx are removed, how do the end caps come off?
Then the cross bars just slide off.
Correct?
Thank you,
Bob
---------- Post added at 10:10 PM ---------- Previous post was at 09:03 PM ----------
Found it under Cross Bar Removal.
I should be all set---.
Bob
Wakinvol
East TN
Yes, they (rear pieces) come up and unsnap from the rails. The cross bars will then slide right out the back. Did mine a few weeks ago.
BobMc
BobMc
It should be pointed out that the "tab" that lifts up to remove the end caps is actually on the top portion of the rail--in the grove of the rail.
My cross rails are off and I start a 7,000 mile trip next week.
I wonder how much my fuel milage will increase???
What a dreamer I am!!
Garret813
I'm curious what the benefit of removing the crossrails would be. Is it just for looks or does it actually improve airflow? Never really heard of people doing that so I'm curious about y'alls reasoning.
BobMc
BobMc
I have not figured out the gas milage deal--that would be nice to see an increase as I have a 7,000 mile trip coming up.
I honestly believe that the truck is quieter without them.
Bob
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
i just did this the other day. There are 6 total. 4 on each end and one in the middle of the rail. Unbolt them and they whole Rail comes off.
BobMc
BobMc
Not to muck up the water--
We were only talking about the end caps and cross rails at the beginning of the thread.
Bob
KMeloney
I think it'd be really helpful if someone made a how-to with pics regarding the cross rails removal. I remember that I couldn't figure out how to get them off when I went to remove mine, and so I ended up taking the whole rack -- with everything intact -- off as one piece. When I slid the rails off with the rack off the truck, I remember thinking that there was [still] just no way to get them off with the side rails on the truck. The tabs seemed pretty inaccessible.
BobMc
BobMc
Too late for pictures from me.
BUT--
Get up on a stepstool and look at the rear of one rail. There are two torx (#25) to remove from the endcap on each rail.
After the torx are removed, reach inside the "U" of the rail with a screwdriver and lift the tab on the end cap and it will slide right off.
put a towel under the end of the rail and repeat on the other side.
Put a towel under the end of that rail and start working the cross rails off.
Bob
bloke
Atlanta GA
I don't post up much, but just wanted to say I find this forum a wealth of information, and wanted to thank all the guys whose advice I have used (without them even knowing) over the years and tonight is no different, roof rail cross bars removed in minutes, with zero problems.
cheers lads, I'm sure I owe somebody a drink :D
HUMBL57
AC Guru
Phoenix, AZ
I agree. Great info! Mine will be off Saturday! I have read that if they can't be removed they should be moved all the way rearward for least noise and best fuel efficiency, so that's where mine have been since it's first wash. But bye bye all together now
tonaaayyyy
I would like to buy the cross rail if anyone have them
Yukon-Jack
.... well I've had three or four Suburbans, loved them all. I've removed the roof racks (RR) on all of them. Why ? Because here in Western NY we have this white stuff a few months out of the year that is a pain in the ass. The racks are an unused nuisance. Now we've got a 2019 Denali, with a new attaching system/method. Any advice ?
Moderator
People's Republic of Colorado
I would suggest posting this in the appropriate year section; you may get better responses that way.
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
Remove the attaching bolts and then it wont look like a wheeled wagon from behind. Mine were off the first day.
HeavyHoe03
