Reverse LED wont fit into G5 housing
kal_59
I went onto VLED and bought this pair. But it won't fit into the reverse light housing of the G5 tails. The bulbs would fit into the stock but not the G5. It's just a fraction smaller. Is there a way, apart from filing, I can get them through? ImageUploadedByTapatalk1354229795.238057.jpg
Gzes
the drifting 2dr
Wichita tx
Yea the leds look huge. If you want yo can order smaller leds or like you said filing but if you.**** up ur screwed unlike maybe $20 of leds. Its your choice but id rather get smaller leds
kal_59
kal_59
You know wher I can get similar LEDs ? Would appreciate if you can give me a link..
Gzes
the drifting 2dr
Wichita tx
Well what size is the led you have right now and whats the bulb size so i can look it up. I have the old style hoe sl am not familliar with the new bulb size
kal_59
kal_59
These Are the only ones I could find with the lens. If only the housing of the light can be 1mm wider or the bulb 1mm smaller I would have fit it in. The bulb type of the one i have is 7440_7W_HP_W
WITCH1975
