Replacing torque converter - with what?
intheburbs
SE MI
Asking the question here, even though it's a pickup, not an SUV. But it's the same powertrain...
Rear main seal needs to be replaced in my 2009 Denali. It has 150k miles, and we plan to keep it for quite a while longer. Since we're dropping the transmission, I figure it's probably a good time to proactively replace the TC. I can get a Delco reman from Rock Auto for $344 after the core charge. Any reason not to do that?
Totally stock - I've never done any extra work on it, not even a tune. Frankly, I don't trust myself with any more power/capability.
Geotrash
Dave
Richmond, VA
Yes. You want one with a billet cover because it solves a problem with the original that contributes to early failure. I have a CVC BU60FHD and I’m happy with it. @NickTransmissions may have another recommendation.
NickTransmissions
Sin City
The transmission bench
Billet cover if you frequently tow/haul or otherwise live in a high heat climate. Make sure the new converter has a converter clutch that's at least .050" thick (my builder uses .070" thick clutches).
If the Delco reman uses the same garbage .020" thick clutch, hard pass.
donjetman
I installed a Precision of New Hampton tc, # P4646, 4+ yrs and 57k miles ago when at 132k miles I had my tranny etc out to do a rear main seal job. $218 and no regrets.
intheburbs
intheburbs
SE MI
Don, it says that's for a 6L90. The 4645 is for the 6L80. Are they interchangeable? I have zero experience with this.
Geotrash
Dave
Richmond, VA
It's second hand info, but the transmission shop told me he uses the same model BU60FHD in both the 6L80 and 6L90, and it was listed as compatible with both in the CVC catalog at the time, so my bet is that yes, they are interchangeable.
Foggy
KS
PATC in louisiana makes good converters too... The "stock" core one has a beefed up clutch and you can also
order whatever stall speed you'd like. Mine is holding up very well.. ( with the new cam I wish I'd gone to a
2000 stall instead of the 1800) Stock is about 1600 rpm stall.
Charlie207
LFOD, New Hampshire
What was the stall speed on that converter? I'd go with a new 2500 JMBX for my 6L80, but I want a slightly higher speed to better match the cam I'm installing.
NickTransmissions
Sin City
Contact your cam manufacturer and they will recommend a stall speed range based on the cam grind, vehicle weight, intended usage pattern and final drive ratio. That is the best way to determine the appropriate stall. You want your converter to be "matched" to your cam and where it makes a preponderance of it's power.
992dr
Eastern N.C.
Sorry to dig up an old thread. I just had a question in regard to the clutch pack thickness.
This is quoted from the sales rep. This particular Converter also has a billet front cover plate.
I had asked him about the thickness, and this is what he said. He also sent me a link from Sonnax.
"We utilize a new woven carbon lockup clutch in these builds. It's the exact material that would have come stock. Same thickness as OEM"
What are your thoughts on this? Stock thickness but a better material sounds good, I think.
Does your guy build them with billet front plates?
Thanks
opfor2
Riverside County, CA
So is replacing the TC easy like removing the old one and placing the new one into the transmission? I too have the same issue as the original poster and I wanted to replace my TC as a PM thing before it goes out since the trans will be removed to replace the rear main seal.
donjetman
yes it's easy once the tranny is out.
MWD_CTSV
Thanks
The Sonnax woven carbon friction with the billet front cover plate will give a longer live and perform like OEM. I would have no issue with a torque converter rebuild with that clutch, especially for a stock replacement.
Sonnax also sells the Borg-Warner high energy frictions as well, which some rebuilders prefer. The HTS friction is the best for TCC slip in the stock application and comes in 1.1mm and 1.7mm. Even though this is a high quality friction, I don't think it can compete with the woven carbon (unless you disable TCC slip), so many prefer the thicker version, because it will wear over time, and more friction equals more life.
992dr
Eastern N.C.
Thank you MWD_CTSV, I appreciate the input and info. This converter sounds like a good option for me.
spectol
