I haven't looked into any body lifts for my Escalade but I did put a 3 inch body lift on my ZR2 S10 back in high school. Not sure where you live but I live in NE Ohio so I had to deal with lots of rusty bolts. I broke one off in the bed and it was a HUGE problem. Usually you have to make your own bumper mounts to move the bumpers up to the same height as the body. You should check out your front end and rebuild it while your doing the lift. I went with all proforged parts for mine, ball joints, tie-rod ends, end links, idler and pitman arms ect. These trucks eat up front end parts as it is so when you crank the T bars up they go through them even faster. My ZR2 went through ball joints about every 18 months or so. Id recommend going with proforged or moog, then youll have a life time warranty to back you up when its time for another set. I personally have had better luck with proforged products.
