tRidiot
- Joined
- Dec 21, 2011
- Posts
- 377
- Reaction score
- 293
So I'm considering doing an entire front end rebuild - front hubs and bearings, upper and lower control arms or at LEAST ball joints, sway bar and links, pittman and idler arms. I may do the late-model Silverado brake upgrade while I'm at it - why not, right?
So my question is, can I replace all these parts from my regular Tahoe with the equivalent parts from the 2500 Suburban? I've upgraded to the 6.0LQ9 engine, so I just thought, "What the hell, why not?" I would ASSUME they are all bolt-on same/same, and watching some videos, I don't see why not. Also would ASSUME that the 2500 parts would be slightly more durable for the long term. With a newly rebuilt 6.0 and 4l60e trans, I guess I need to count on keeping this thing for a while. Figuring on maybe $1500 or so worth of parts (guesstimate), I won't do GM OEM, but AC Delco and Moog (the higher line) for most, I think. Also all new bushings, probably Energy Suspension - from what I've read, they're nice. I'll eventually also likely upgrade all the body bushings.
This a reasonable start to rebuilding the drivability, stability, longevity and enjoyment of my 2004 Tahoe LE?
