Rear window switches dont work
FINALTOUCHFRI
Florida
I can control the rear windows from the drivers controller but both rear windows wont go up or down by their own window switches. I can control the passenger front window also with the drivers controller.
Im also looking for driver and passenger side view mirrors. My motors are shot. 07 Tahoe LTZ.
Big Mama
Virginia
Need new switches most likely. I know it seems like they shouldn’t go bad at the same time but it’s common. You can bench test the old switches or move the front passenger switch around (couldn’t tell if it works from description) and test each one they’re all the same. There are several suppliers on line for mirrors or you can check boneyards. There’s also a rebuild kit for them.
If you need new swtiches:
https://www.ebay.com/itm/Rear-Passe...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
I'm told these come from the same factory that GM uses. So instead of spending $23, they are about $8 for the same switch. Bought two so far and they work perfect.
Drewphil
