Rear heat wont work
Oklahoma
As it says my rear heat does not work. Is there like a seperate heater core for the rear or something else im missing?
Grocery Getter
A guy with a truck.
Phoenix, Az
I have the same issue. My rear AC works just not the heat and the temp controls don't work on any of my heat/ac. It's either full blast or nothing, hot or cold. Any suggestions?
blueflamed03
Oklahoma
mine too, will do some diggin today, hear that it may be a rear door not actuating correctly...will look today.
blueflamed03
Oklahoma
rear panel
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
some of yalls symptoms sound like the blower motor resistior. I would replace that and go from there, its like a 50 dollar part and you can change it out your self in a matter of minutes.
T3rry
Calgary, Alberta, Canada
if you take the panel off you should be able to see the blender actuator, when you move it on the controls, you should see the shaft in the end rotate.
Conedaddy
