Rear Differential Whine
EddieC
We had a serious rear differential grinding noise all the time, on and off the throttle. Trans shop changed the carrier bearings a month ago and it seemed good or a while.
But after a couple weeks we're getting a loud gear whine noticible above 40 mph when lightly on the throttle. When coasting, the sound subsides but touch the throttle and it's immediately back so it seems loading the gears is the key. Popping it in neutral while coasting makes it silent.
Any ideas?
Foggy
KS
sounds exactly like a bad ring gear (ring & pinion need replaced)
EddieC
EddieC
The transmission shop, claiming to have lots of differential work under their belts, had said they fixed all that needed fixing when they changed the carrier bearings so I have reservations about throwing good money after bad. The work done didn't cost all that much but it's a PIA now.
Should I just have all the guts replaced somewhere else?
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Would they be willing to double check their work? Maybe they didn’t get the crush sleeve on the pinion all the way or something changed like it came loose.
EddieC
EddieC
Not sure they even took it out being they only changed the carrier bearings which I am guessing are two bearings.
I did notice quite a bit of backlash before and after the service. I don't know if that could have been addressed but it wasn't if it could have been.
jz57
1) What model/year/mileage of your truck?
2) Did you get back all defective parts back from shop after rear differential job has been done? That can help us to dermine what parts were replaced.
3) How much did shop charge for the job? That can help us estimating how much job was done.
4) Based on your original symptom, the grinding noise usually comes from broken spider gear set. The repair should be more than replacing carrier bearings.
5) After repairing, the noise became whine, which is usually caused by ring and pinion gears backlash which should be within 5/1000 - 12/1000 inch. The job is including adjusting shim thickness between carrier and differential housing on both driver and passenger sides.
EddieC
EddieC
2)Did you get back all defective parts back from shop after rear differential job has been done? That can help us to dermine what parts were replaced.
1) 2008/100,000.
2) No parts returned but Invoice and verbal description stated only carrier bearings and axle seals were addressed.
3) $400, like I said "not too much".
4) I can't speak to that. It was a constant gear grind sound but otherwise drove around without physical symptoms other than the noise. I've broken a spider gear 55 years ago and the car wasn't moving after that bit of adolescent behavior.
5) It seemed quiet at first but now the whine is escalating with each drive during the past 2 weeks. It's been about 700 miles since the service.
strange that they would do the wheel bearings, carrier bearings, and not address the pinion would have been real easy at that point now it's going to be $600 just for that
jz57
The price of $400 to replace carrier bearings is very good!
Here could be the ticket:
The issue is isolatd to carrier bearings area: adjusting shim to meet backlash or carrier bearing clamp bolt torque to meet GM specification (55-60 Ft.Lb).
Perhaps the price was too good to do extra job (backlash/torque) for you.
91RS
GA
If everything was done correctly, then it's either pinion bearing(s) or the ring and pinion gears themselves. This is why I'm hoping buying a used differential for mine is the way to go to save a lot of hassle replacing everything.
EddieC
EddieC
The thing is I didn't limit the job and that was not the original ballpark estimate for all bearings which was double.
I was prepared to replace everything and he knew it but when I picked it up he said that all they needed to do was the carrier bearings.
So would it be too late to make the adjustment or better to just write it off and have someone else make it all fresh?
EddieC
EddieC
I priced that out and around here it was running $1800 and up plus shipping and installation for a minimum of 150,000 mile unit.
I had another quote for $1700 for complete rebuild with all new parts whether it needed them or not but the scheduling was not good at thew time.
bigdog9191999
sw michigan
i had a situation where the rear cover rusted and slowly leaked the gear oil out so i ran it low pulling a trailer for about 150 miles loaded, then another 150 unloaded before i noticed, it was a cold winter day and that probably saved a little, but there was very very little metallic when i cleaned it out to change the cover so i ran it. it makes noise almost identically as described whine when on the throttle lightly and quite when coast. the wear pattern could be seen a little more pronounced than average but otherwise looked good, as i can deal with the whine we just cleaned it up an treated it like normal and i am just aware that it will make a little noise, basically forever. the only way to fix my particular issue would be ring and pinion ( which we attempted when we swapped the axle from one truck to another, but there was enough difference that we decided that it wasnt going to be worth the effort to make it correct and wanted the truck drivable quicker, being it was more "comfort" issue than a reliability issue.
EddieC
EddieC
Bigdog,
Thanks for that input but unfortunately our whine is distractingly loud and those things bother me just not knowing if it will leave either of us stranded somewhere. I actually liked my Muncie rockcrusher whine this is a different situation.
EddieC
EddieC
The other two shops on my list are booked out for more than a month so I guess I need to give the original shop a chance to take a look at it now that there is the noise that shows a shortcoming.
91RS
GA
I’m not sure where you’re looking but I just had a 96k mile unit from a 2012 delivered for $520. They had a bunch cheaper than that one. They had one with 130k for $280 with damaged backing plates but I wasn’t looking to take mine apart to swap them.
EddieC
EddieC
Not here. The shop that does other heavy repairs for me did a search on his system and many units came up at the price I noted and above) and none were even in our state. Maybe I should note it's a Z71 with a locker so maybe the combo makes them harder to come by. Scrap yards are becoming scarce around here, I presume because of environmental liabilities.
I remember in high school we had a great junkyard where $50 a day let us carry out everything we wanted. One trip yielded a hood, radio, bell housing and tranny to fit my '56 Chevy. Certainly better days.
EddieC
EddieC
So the saga lives on.
It went back to the original shop to get checked. The whine was acknowledged, the gear pattern checked and deemed good. Slight wear on the gears was noticed. Ruled out pinion bearing issue because the noise is gone if the truck is shifted into neutral while rolling. The whine is primarily there when there is force on the gears, most noticeable with light throttle and it gradually curtails when lifting off throttle and as noted, silent in neutral.
The proposal was to replace the gears by process of elimination.
I don't think I mentioned that synthetic lube (per GM recommendations) was not used in the work but I don't know if that is critical.
Perhaps the whole thing should be torn down by a different shop. I have a line on a 4x4 shop and on an axle specialist.
Any more thoughts?
dizhai
