R1 Concepts Rotor/Pads install and making wheels pop!!
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
on customers trucks i get a wire brush disk for a drill and i clean off the rust then spray over it with rustoleum
TheAutumnWind
Sorry im digging up this old thread, but this is a great idea. Fosscore's build pointed me here. Ill be doing this when I upgrade to NNBS front disk.
Fosscore
Yeah man. They still look good too. Worth the effort IMO.
05Single
afraid of the dark
No prep before paint ?
I'm sure it holds up in Cali or Florida sunny and dry weather all year long. Dont see it lasting in the winter states.
Please prove me wrong :shrug: cause this makes for a pretty clean look.
And maybe add an after pic (5-10 miles) :deal:
TheAutumnWind
First off I used hi temp semi gloss. Next time Ill use the enamel I think.
Clean them well. I used a lot of brakekleen. If they are already rusty hit em with a wire wheel on a drill or something. The paint wears off on the top hat where it contacts the wheel of course (not visible).
I use pretty aggressive wheel cleaners and a powerwasher and i have removed some of it on my calipers. This is likely due to poor prep on the calipers. I didn't spend enough time cleaning them, and again I think I would use the enamel that is suggested next time.
I've done this now on a couple vehicles and it helps quite a bit, even my beater with steel wheels and hubcaps lol. Hate that rust ring especially when behind some nice wheels that show them off.
05Single
afraid of the dark
This method confuses my small brain. All I know is sand before paint (adhesion promoter). Except plastidip of course lol
05Single
afraid of the dark
Damn im slackin lol.
Well was wanting pics from the OP to complete the thread instead of thread hopping.
AppocAlexx
Darth Appocalexx
Abilene TX
I don't see how this does not effect stopping performance? Enamel does gunk up even with sand paper at speeds no faster than your hand can go. Add the speed and friction and heat regular braking then you will eventually have issues. Unless there is a way to test this theory that it does not effect braking performance and prove me wrong I would not spray and then throw the pads on and then just trust that the paint comes completely off the pads after the 5 stops of 50 or w/e. Instead of using new pads I would first run the old pads and let all the paint rub off the surface area with a few stops then go back and add the new pads. Just seems pretty dangerous to me and although it does look damn good I would go that extra mile and do some extra work for safety. Looks should never out weigh safety.
:2cents:
Sorry if it sounds like im doggin on this mod and obviously from a prospected person. Been working on cars since I was 10 and father for his whole life and I would just not trust it. Great idea tho, but like I said just do a lil extra work and replace the pads after the first ride is all I say.
TheAutumnWind
:2cents:
I understand what your saying and felt the same way before. I can say that it doesn't effect stopping performance in any way once it has been worn off.
05Single
afraid of the dark
I'm thinking powdercoat then take it to a shop and have them turn the rotors. Forever coated .
varminpoolteam
