Questions and Answers about Vanquish Auto
Vanquish Auto
202 Wallace Ave N Unit 12 Lehigh Acres FL 33971
Please post your lighting related questions here. any year, make and model is ok.
I would like to start with a question from Chris ( oilfieldtrash78 )
"What puts your kit over the rest? I just want a kit, that once it is installed, it stays working without any issues.
Thanks for any input you may have"
Hello Chris, thank you for checking with us. There are three biggest reasons right now, the first one is the oem corrected beam pattern, this alone puts the kit where no other kit has been before, this is a new feature and all our lights have been recently overhauled with this important new feature. The quality of the bulbs is also the highest possible, making it way brighter. The most important feature of our kit is the ballasts we offer, it's can bus ( you won't need relay harness or capacitors to run them on your vehicle) it can work perfectly well with daytime running lights or automatic headlights and you won't run into any kind of issues if installed correctly. Which we will provide you our help on getting it done right. Simply put, other kits are outdated compared to this, no exception and the quality is not comparable. Notice the size of ballast, igniter and can bus, this can bus ballast is the only one that works on many more complicated vehicles than yours. Our bulbs are at least three times more expensive to produce than the runner up we used to have. I hope that helps, feel free to contact me with any other questions. Have a nice day!IMG_0679.JPG
John Root
I have a Chevrolet Tahoe 1500 4x4 I changed front pads ,rotors, wheel hubs , brake lines, flushed system, calipers, Brakes drag after 10 minutes of driving.
Big Mama
Virginia
John, you may get more responses posting this in its own thread under your model. There are also tons of brake job threads under the search.
John Root
Thanks a lot dear! i am also thinking for creating a new thread and hope will get nice response from this community.
Big Mama
Virginia
It’s a great community with tons of experience. I’ll watch for it too. Add in your post which ones you did (front/back or both) and which ones are dragging. You’ll get plenty of help.
Ihaveatahoetoo
