WingsAA
CMFIC
So as you know when you install the Belltech 2-3/4 kit from Tony it messes with the angle of the rear stock sway bar unless you get the shorter djm endlinks. Here's my situation...
Before my drop I had already upgraded to the Hotchkis sway bar kit both front and rear with upgraded endlinks: (Rear sway bar is the bar with bent up ends)
Due to the bend in the Hotchkis bar, I couldn't seem to get the shorter djm endlinks to mate up correctly so went back to the provided Hotchkis endlinks. Since the Hotchkis bar has the different design/bend... I can just use a shorter endlink without having to offset the swaybar and everything clears fine. Overall, the sway bar angle doesn't seem to be horrible but I'd like to find shorter or adjustable endlinks that would allow me to "dial it in". Last resort could be is to hack the Hotchkis endlinks in half and thread them and make my own adjustable links.
Just wanted to get some feedback from you all since you've helped me a ton already.
Thanks in advance!
Thanks in advance!
