Q: Stock alernator information
Popeye
Ontario, Canada
98 Tahoe OBS, Stock
I want to wire a dual battery setup so that i can use other items while not running the engine and still be able to start the truck, i.e. camping scenario. In order to purchase a isolator i am trying to figure out the stock alternator amp output, so that i can get something bigger than that. (i will change the alternator in the future, not now).
Reference
Also what kind of a isolator should i get? Is the PrincessAuto isolator good enough? Have heard mixed reviews and would like to know if someone here has first hand expereince?
thx
faze
British Columbia
The alt on my dual battery '95 2500 diesel was a 100amp. I think you can get a 140. Look at rockauto.com under a 2500/3500 series truck.
TigerEyz3
Slow and Steady
TN
Don't have any insight into your isolator questions, but the stock alt on the OBS 1/2 tons is typically a 105a - there's also a 140a option.
When the time comes to upgrade/replace your alt, I'd personally suggest going with a ** model that way you've got more power available at lower rpms (I've got a large case 220a from Iraggi and have had zero problems).
hoondueces
Would anyone be interested in doing a write up on howto install a two battery setup? I also have a 98 tahoe that I am trying to do this with
Popeye
Popeye
Ontario, Canada
Click on 'Reference' in my 1st post in this thread. there is a write up there on how to do a dual install. I just finished mine referencing that post.
JamesinAbilene
