Pioneer radio
Ramiro0727
You will need both of these...
iDatalink HRN-AV-GM5 Maestro RSE Retention Harness for Select 06-14 GM Vehicles.
iDatalink ADS HRN-RR-GM5+ Interface Harness Chime Speaker for select 2006-up GM
If you have a 3rd row screen then you will also need to splice a couple wires i believe but i don't have a 3rd row screen so I never bothered to figure it out.
I believe Wes @Doubeleive or one of the other guys can tell you more about the 3rd row mod.
And here is all the wiring you get to stuff behind the HU....
Kbuskill, Will those harnesses keep the factory Satellite radio?
Thanks,
Ramiro
kbuskill
NE. FL.
kbuskill, If you try it. Please post your results. Before I make the purchase of these harnesses
Thanks,
Ramiro
So the answer is... Yes it works.
I signed up for the 3 month free trial and it works just fine.
Ramiro0727
Kbuskill, Thank you. Now time to order a new head unit and the harnesses. My Rosen unit crapped out. Its stuck on the flash screen. All that works is the radio.
Ramiro
kbuskill
NE. FL.
Ramiro
My Rosen GM1210 did the same thing. I upgraded to a Kenwood and am very well pleased.
FYI there is a company on ebay that will fix the Rosen. I contacted them and sold them my old Rosen for like $90.
***EDIT***
I think this is them...
https://www.ebay.com/itm/302780028891
Ramiro0727
kbuskill, I will email them. I saw them on Ebay also. I rather would go with a nicer headunit than the Rosen. I thinking about the Kenwood DMX-706S. As long as the headunit can play movies thru USB to keep my daughter entertained during some trips on our factory rear screen.
Thanks,
Ramiro
kbuskill
NE. FL.
Thanks,
Ramiro
I went with the DNX575S and love it.
Ramiro0727
kbuskill does the maestro RR put the rear camera screen on the headunit. Right now my rear camera view is on my rear view mirror. Or I will have to splice into the camera feed to get to display on the new Kenwood headunit.
Thanks,
Ramiro
kbuskill
NE. FL.
Thanks,
Ramiro
You will have to splice it.
Ramiro0727
Kbuskill do you happen to remember which cable there are. I never got around to splicing them when I had my Rosen stereo. I ran the video cable to it back then. Hopefully I exposed the wires I need back then. I will see when I install my new headunit
Ramiro
kbuskill
NE. FL.
Ramiro
My Burb had the video in the HU from the factory instead of in the mirror.
You can tap into the video feed under the driver's side dash. Can't remember the exact wire colors or location but it has been done many times and is pretty well documented so shouldn't be hard to find the info.
Ramiro0727
Kbuskill, I received all my harnesses. Quick question . Did u connect the stereo harnesses to the maestro GM÷5 using the low level inputs or the high inputs?
Thanks,
Ramiro
Sent from my SM-N975U using Tapatalk
kbuskill
NE. FL.
Thanks,
Ramiro
I used the low level inputs.
Ramiro0727
kbuskill, I got it all hooked up and my satellite radio doesnt play. It says check tuner. I know I enabled it when I programmed the Maestro RR. What did I do wrong.
Ramiro
Ramiro0727
Satellite radio works. But I get no sound. trying to figure it out. Radio works fine.
Ramiro
kbuskill
NE. FL.
Ramiro
It has been a while since I did mine but my guess would be you didn't plug one of the RCA plugs into the proper place or something like that.
I would pull the HU and double check all your connections. That is a lot of wiring to stuff into the dash and things can sometimes come unplugged.
I modified the inside of my dash to make more room.
Before....
After...
Pieces I removed...
Ramiro0727
Before....
After...
Pieces I removed...
Kbuskill. I figured it out. I had 2 connectors from the maestro RR crossed. Once I made the correction. Everything worked great. The Kenwood head unit sounds way better than the Rosen I had before. Tomorrow ill tap into the video wires for the reverse camera. So it can show up on my stereo. Thanks for all your help. Greatly appreciated.
Ramiro
TejasPitt
