Pedal Commander
dsh1106
39.7594° N, 84.1917° W
Hey guys and gals,
I did some reading over at silveradosierra.com and they do the "paint stick mod"... and the Pedal Commander product for throttle response enhancements.
From what I can see, the throttle pedals are different on the trucks, because on my Tahoe there is on way to use the "paint stick mod".
Is anyone out there using one of these to get a more responsive throttle pedal?
Scott
PG01
Up here to the right
Had to google ‘paint stick mod’
I know a few here have used The pedal commander with good results. Lets see if the chime in with their thoughts.
@humer101
Tiredmechanic23
Hey guys and gals,
Scott
The pedal commander is just a mind trick. https://www.krawlzone.tv/how-do-pedal-commanders-work/
It is the same thing as putting your foot into the pedal more. Save the money and just use your foot a little harder as its exactly the same thing. If you give the throttle save 25% the commander just tells the computer its at say 28% instead of 25. If you had just put your foot down a bit more it would have been the same thing.
So best advice save the cash and just be a touch more lead footed. Do not fall for the placebo effect.
St. Louis
Either the ITM (Italian Throttle Mod) which is moving the seat closer just a hair or if you have adjustable pedals move them closer just a smidge
PG01
Nothing to do with the seat, adjustable pedal set all the way foward then hold it for a sec to come back up.... much more pedal resonse
St. Louis
I didn't think all models had adjustable pedals.
Ah, yes- the legendary Italian Throttle Mod! Makes the Italian tune-up that much easier.
Melissa1971
