Hey guys and gals, I did some reading over at silveradosierra.com and they do the "paint stick mod"... and the Pedal Commander product for throttle response enhancements. From what I can see, the throttle pedals are different on the trucks, because on my Tahoe there is on way to use the "paint stick mod". Is anyone out there using one of these to get a more responsive throttle pedal? Scott
Had to google ‘paint stick mod’ I know a few here have used The pedal commander with good results. Lets see if the chime in with their thoughts. @humer101
The pedal commander is just a mind trick. https://www.krawlzone.tv/how-do-pedal-commanders-work/ It is the same thing as putting your foot into the pedal more. Save the money and just use your foot a little harder as its exactly the same thing. If you give the throttle save 25% the commander just tells the computer its at say 28% instead of 25. If you had just put your foot down a bit more it would have been the same thing. So best advice save the cash and just be a touch more lead footed. Do not fall for the placebo effect.
Either the ITM (Italian Throttle Mod) which is moving the seat closer just a hair or if you have adjustable pedals move them closer just a smidge
Nothing to do with the seat, adjustable pedal set all the way foward then hold it for a sec to come back up.... much more pedal resonse
@iamdub named it after me when I posted moving pedals a tiny bit foward after bottoming them out gives the truck more pedal....more of a dig at me...
