Passenger door elec. probs
ccgrayhoe
Jacksonville, fla
Ok this is the problem. There is no power going to my front passenger door. Pwr lock, wndw and side view mirror doesn't work. I woke up one morning and I tried to unlock my doors using the keyless entry....nothing. Any suggestions. I've checked the fuses..fuses ok.
mwitt
I'm seeing what seems to be the exact same problem. Out of the blue, my remote transmitter wouldn't unlock or lock my car, the front passenger window won't roll down with the passenger or driver side controls, and the front passenger side lock doesn't respond to the passenger or driver side controls. I did't check the mirror controls.
I can't help but to think that the alarm, windows, and locks are all tied together somehow since it all happened at the same time.
All other door locks and windows work.
I can't make heads or tails of the fuses.
Any ideas???
WrenchGuy
WrenchGuy
I'm in for this one!
I have the same issue. I've gone through 2 switches so far. No shorts or anything.
?????? I was hoping it wasn't just me. My fob/keyless entry quit out of nowhere too but the alarm will still go off.
This would be real cool if we figure it out. I jumped the motor its good. Continuity through the whole harness too. I went from my old switch to a salvaged one and it worked for like 4 days. Now I want to see WTF before I buy another one.
OP thanks for bringing this up I have been doing audio and haven't dawned on the door issue lately.
mycadilac
I have the same issue. Just changed out the driver door window regulator... Then found out there is no power going into the the main switch.Every other windows/locks are working find just no pwerto the driver door.. Is there a fuse or relay some where that i need to be check?
Thumper8302
OKC, OK
i dont have the lock or window issues you all have (YET). But my factory fob doesnt work anymore either... changed the battery and it still transmits but the vehicle wont recognize it..Ive read some things bout our vehicles and people have brought up the body control module... might be something to look into
homedic3181
Northern NJ
:ehcapt:I hope this might help you guys a little bit. I have an 04 hoe and last winter everything on my passenger side front door went out (locks, mirrors, heated seat) the fact of the matter is in our trucks the passenger side window switch is a module and when it goes bad it causes all of this to occur. The only down side is not only is the module itself a little pricey as far as switches go, you then have to pay gm to have your keyless entry recoded for the keyless entry remorts to work again.
vsaravia
