Parasitic draw
03GMCYukonXL
Ok so my 2004 Tahoe has been dying in about 2 days. It was about every 5 days but it has gotten worse. There are 2 things I have in mind but I'd like to get some input from this forum before I go digging. So, when it's warm outside, the gauge cluster will take about 30 seconds to a minute before it starts working. The second thing, is when I put it in 4wd, the switch clicks lightly but rapidly the whole time but only when moving forward. The last thing is, when it's really quite, I can get in the truck and here like a buzzing noise that seems to be coming from the cluster, but I can't tell for sure. Is the cluster the first place I should start looking?
TJ Baker
Colorado
I have a little gadget that plugs into a fuse socket and displays current flowing. Got it at Harbor Freight. I would check for a power draw to the cluster at the appropriate fuse after allowing time for the system to go to a sleep state.
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
If you watch the videos, it will tell you the process of the diagnostics. Plus, if draw is intermittent, it makes the diagnostics harder. The self contained battery, makes it so you can disconnect the vehicle battery without losing the circuit continuity. The process starts by seeing a draw that is "too big", usually over 50 milliamps, and then watch to see the draws diminish as different modules will go to sleep, so to speak. The diagnostic process is the same though. Start removing fuses and relays, one at a time to narrow the circuit that is causing the draw and then see what items are on the circuit and check those items.
There are several you tube videos on the diagnostic processes. watch several of them because some are better than others.
here is what you do
pull the cluster out to where you can reach the harness, but leave it plugged in.
turn off the interior light switch so they do not come on when the drivers door is opened and/or roll down the drivers window.
then pop the hood and get your meter out.
disconnect the negative battery cable and connect the meter between the battery negative post (red probe) and the battery negative cable (black probe)
switch the meter to amps and monitor the draw, wait 10 minutes (this allows the vehicle to go into full sleep mode), note the amp draw.
then go over and unplug the cluster and see if the draw drops
if nothing changes, then it's not the cluster. proceed to the underhood fuse box, remove the cover and pull 1 fuse out at a time while monitoring the meter until you find the one that makes it drop.
Fless
Moderator
People's Republic of Colorado
Make it easy on yourself and do some targeted diagnostics first. No special tools needed.
Pop the hood, let the truck go to sleep and get out your voltmeter. Use the test points to measure voltage drop across each accessible fuse (one of these will be for the cluster, but check all of them) and you'll find the circuit that is drawing power.
Measure the voltage drop across the fuse test points and convert it to mA using the PowerProbe charts that are available online (https://powerprobe.com/wp-content/uploads/2025/06/fuse-voltage-drop-chart.pdf) . Essentially any fuse that has voltage drop is supporting a circuit that has current going through it.
strutaeng
Dallas, Texas
Probably the cluster. It's a common issue related to the lead-free solder breaking down over time causing battery drains. I think eric on the video @Fless posted actually called company that rebuilt the cluster and that's what the technician told him.
I would just pull the cluster fuse and if the issue is resolved, get your cluster rebuilt. Do the LED lights upgrade while you are it and add the transmission temperature guage.
TonyS1203
Does your rear parking obstacle warning (Parking Assist) work?
Fless
Moderator
How do I get in touch with him?
And for @OR VietVet so he can provide it when he recommends
https://www.fixmygauges.com/ if you want to buy one, and have the option of sending yours in to get more than a one year warranty on the one you buy. Read the details on the site. Carl does a great job.
If you want to send yours in for repair, hit the link and scroll to the bottom of the page for the offsite repair person's email.
West 1
My 2003 dash cluster failed at around 125,000 miles. $150 for a full rebuild and everything was perfect after that. All gauges read correctly and the amp draw issue was gone.
CRN_25
