Paint touch ups and rust repair
992dr
Eastern N.C.
Man, I'm scared to take my running boards off.
I've seen a video on tipping/forming metal using a wood buck that really opened my eyes on repairing some of this body work. It's a lot easier than it seems to. I think the hardest part is making the buck with the correct angles for each body part. His channel is "Make It Kustom", really cool sh*t if you're into that kinda stuff.
tungsten
tungsten
I have had more than my share of that and trying to fix them, do not miss that at all.
Its kinda fun,Im able to just close the garage door when I want or get tired off it.Would be better if these pieces weren't so complicated.Winter is knocking at the door also so kinda pressed for time.
tungsten
tungsten
Yeah I’ve been using whatever I have around to bang the metal into shape. Wood is easy to shape. This new piece though is a bit tough. May have to split it in two shape then weld back together not sure. I’m just looking to have some solid metal that I can bondo over.
This was from the other side. I’ll need it again around this wheel well.
992dr
Eastern N.C.
This was from the other side. I’ll need it again around this wheel well. View attachment 383598
Yes, wood is definitely easy to work with
Ahh very cool
Nicely done
tungsten
tungsten
I may get some 20g as its easier to shape then the 18.Welding the 18 works well though cause if you blow through the original you can build up on the 18 to fill.
992dr
Eastern N.C.
I'd definitely stick with the thicker material.
Worst come to worst, you can cut and weld each piece instead of forming.
How are your rockers looking?
tungsten
tungsten
Rockers are fine,a little surface rust around where the vertical bolts go.Was fully expecting holes but nope.
tungsten
tungsten
So after an hour weight at the paint store I’ve got the 3rd attempt at a closer match. The last one looked real good with the led light on it but not so much in natural light,had some blue in it. So did a test piece this time with black primer and looks good but that’s what I said the last two times. Fingers crossed. Front fender taped off and primer applied. Hopefully have time today to get paint on this part.
tungsten
tungsten
Well match looks better. Hard to tell only have a few windows in the garage
working on the other piece by the rear. Cut grind weld repeat. Kinda got it close.
tungsten
tungsten
Got it tacked in place. You can see the void or reverse shape I need to try and get. Only thing I can think of is cutting it along the line push it in and re weld. Or something like that haha.
tungsten
tungsten
Think Ill look at for a while,look at the other side to see how close it is.Have to scab in a piece for the inside door frame.
I think I have to weld it all in place to keep it firm then try to get the curve S shape going? I dont know,Almost time for a beer.
tungsten
tungsten
Got the piece tacked in. Cutting the slots gave me what I needed. Had a spot top right still had rust welder just blew through it. Cut it out and patched from behind. Much easier.
tungsten
tungsten
Some questions about HVAC,havent driven the truck much but noticed the "rear" button.Didn't start the truck so assuming this turns on the rear heat. Battery is disconnect so haven’t played with it. Can you have it so the rear heat turns on with the front controls? Will it work with auto start?
Thanks.
tungsten
tungsten
Grinding away on th back fender. Found a few more spots where it was soft. I could probably cut the whole fender lip away but don’t want to do another one. No doubt rust will re appear again By next year regardless of what I replace.
At least this will only take a few hours.
tungsten
tungsten
Got them mostly tacked in. Sitting on the ground gets a bit tiresome so done for today. Hopefully get some bondo on tomorrow.
MonteJ
