P219B
itsbo1313
Louisiana, MO
So I removed the intake manifold and associated parts to replace the oil pressure sensor and now I have a p219b code. I’m thinking it’s the o ring on the injector that came out with the fuel rail. Anyone have experience with this code?
wsteele
If you can see live data with your scanner, is the upstream O2 sensor on Bank 2 switching like normal or flat lining?
Could also be an intake manifold gasket leak as well.
itsbo1313
itsbo1313
Louisiana, MO
itsbo1313
itsbo1313
Louisiana, MO
A quick google search says this is normal. So I’m think fuel injector o-rings.
wsteele
The O2 sensor looks like it is switching (going up and down in voltage, so I agree, it looks OK).
You might try checking for intake manifold leaks along with checking your injector fuel rail seal (the O rings).
sainmegroll
