thefrey
- Joined
- Feb 3, 2025
- Posts
- 419
- Reaction score
- 469
I recently popped a P0521 after about 2000 ish miles post DOD delete.
I had it pop up and clear itself after a drive cycle at one point and then it popped back up.
Not sure if anyone else has had issues with their oil pressure sensor after a DOD delete.
I am seeing no issues with the current sensor. I don’t have a mechanical sensor to verify the readings but they have been consistent.
I am running 5w30. I installed a new Melling 365HV pump with the stock spring installed.
I haven’t figured out when it happens yet, but my assumption is that it either has to do with the raised DOD pressures or maybe just coincidence of it going out. The sensor is 10 months old but I know these are notorious for going out.
Cold start is ~70psi, cold acceleration is above that
Hot cruise is 42 ish psi at 1800rpm
~60psi at 3500rpm
Hot idle is ~20-25
Pre DOD delete was 45 cold start, 30ish cruising, 15 idle
Is there perhaps an oil pressure table that correlates with RPM that needs to be reset or relearned over time?
~60psi at 3500rpm
Hot idle is ~20-25
