Oil Filter recommendation
Smokymance
Boosted
MI
ANYONE EVER USE WIX 57045...some of the TBSS boys use it...its taller than the 57502, which is taller than the stock 57060.
tlsnokuyeulb
I also use wix. Although I used a napa platinum on this last change. Anyone know what the platinum is equivalent?
D_R_C
I use to use Wix/Napa gold on every vehicle I now own (6),
On my Denali right after the service every time I started the engine cold it clattered for about 25-30 seconds.
Just like a dry start after a oil/oil filter change.
I went to the dealer and they suggest I put in a AC Delco oil filter to satisfy GM before they tried to find the problem.
I did and the problem stopped, it turned out to be a defective check valve on a NEW oil filter.
I then remembered I had the same problem on another vehicle using Napa Gold about 10 years ago, I then went with the manufactures oil filter.
Now I only use the vehicle manufactures oil filters exclusively on every thing I own.
IMO Wix/Napa gold is crap I don't care if those names are on race cars, its still crap.
BigBlueLB756
By Marion, MS
Old thread revival.
Shameless plug:https://www.tahoeyukonforum.com/threads/ac-delco-pf48-oil-filters.100726/
I also prefer AC Delco but have had no problems with Mobil One and K&N oil filters. We are running a long K&N with the pipe thread fitting on the end to make it easy to replace the filter.
Long - PF63, Mobil - M1-212, K&N - HP2011
Short - PF48, Mobil - M1-113A, K&N - HP1017
08grey
Any specific reason why to run a longer filter over the short one?
Sent from my SM-G950U using Tapatalk
Well, it makes it easier to remove. In my racing days we ran longer filters for better filtration, the motors weren't any worse because of it. Old habits too I guess.
GranPrix
Whats the diff between the ..48 and ..48E?
BigBlueLB756
By Marion, MS
Answered.
Which ACDelco filter is the longer one?
ZaZaZazzels
