Oil cooler lines leak?
4myfreedom
Washington, DC
Man I replaced both oil cooler lines and they are still leaking on the driver side of my 1997 Yukon GT. I also replaced the pressure power steering hose what could this be?
992door
Greenville, NC
Yea pictures would really help your pm was kinda vague on details
Sent from my Motorola Electrify using Tapatalk 2
4myfreedom
4myfreedom
Washington, DC
stormingn now but repalced both lines and power steering. But still leaks more so today too
---------- Post added at 08:23 PM ---------- Previous post was at 08:20 PM ----------
I think adapter plate now though all the symptoms are clear.
992door
Greenville, NC
Is it leaking motor oil, Trans fluid or power steering fluid?
992door
Greenville, NC
True but if he is going by drops on the ground could be trans on driver side had it run down the bumper and valance when I had the motor rebuilt they did not tighten the cooler lines back tight. It depended on the way it was sitting where it ended up
4myfreedom
4myfreedom
Washington, DC
motor oil
---------- Post added at 09:36 PM ---------- Previous post was at 09:36 PM ----------
It was oil on the cooling line so I thought it was the lines so I replaced both
---------- Post added at 09:40 PM ---------- Previous post was at 09:36 PM ----------
Oil was going low though so it is oil
992door
Greenville, NC
Did you put the o-rings on the hoses when you replaced them and are they seated good in the fitting?
992door
Greenville, NC
Just to make sure we are taking the same thing. You replaced the 2 hoses that run into the radiator?
992door
Greenville, NC
OK I am pretty sure that there should have been o-rings to go on the connections. Sunlit would probably know for sure whether they should have them.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
there are orings used on each line where the lines enter the radiator and there should be internal orings on the fittings where the rear portion of the lines snap into the quick disconnect. the ones in front are available individually for a $1 or 2 each from a dealer and those should have bee included with the lines. the one in the back the whole fitting must be replaced. those are about $8-10 each gm 15043741.
---------- Post added at 07:48 PM ---------- Previous post was at 07:46 PM ----------
4wd version shown. only difference between the 2wd should be the adapter orientation.
http://www.genmotorinfo.com/Picture...S+(L30/5.0M,L31/5.7R)+-+K+&pid=960515TC01-018
4myfreedom
4myfreedom
Washington, DC
No have to take my bros yukon off the lift. New engine install will keep you posted. sorry its is so slow
CKendrick
