Oil Catch Can added to a 2009 Tahoe
trailblazer
I bought this Chinese half-liter can from eBay for $14. It does not have an internal diffuser so I'll probably replace it in the future. I reused some hardware to make the bracket from yesterday's Tru-Cool project.
I had no clue to where the PCV hose was and where it went to so I found some instructions on the internet for a kit for UPR's $109-159 catch can (depending on the options). Word to the wise - before you cut anything just know that the 90-degree adapter on the top of the engine is not as the instructions portray. I sliced it close to the fitting and discovered that I had destroyed the part. What I should have done was cut the rigid plastic tubing out about two inches. As you can see in the photo, I ended up drilling out the fitting and friction fit a piece of the tubing back into it. Also, I used my OTC Master Flaring Kit to make flared ends on the rigid tubing so my 3/8" hose wouldn't slide off. can01.jpg can02.jpg can03.jpg can04.jpg can05.jpg
This entire project cost about $18 if you account for the six feet or so of 3/8" tubing. I might order this catch can that has a baffle of sorts but is only $23.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I had no clue to where the PCV hose was and where it went to so I found some instructions on the internet for a kit for UPR's $109-159 catch can (depending on the options). Word to the wise - before you cut anything just know that the 90-degree adapter on the top of the engine is not as the instructions portray. I sliced it close to the fitting and discovered that I had destroyed the part. What I should have done was cut the rigid plastic tubing out about two inches. As you can see in the photo, I ended up drilling out the fitting and friction fit a piece of the tubing back into it. Also, I used my OTC Master Flaring Kit to make flared ends on the rigid tubing so my 3/8" hose wouldn't slide off. View attachment 220794 View attachment 220795 View attachment 220796 View attachment 220797 View attachment 220798
Nice work man, I need to get this done! :happy107:
I'd advise against the one with the breather on top since it will be a vacuum leak and cause high and/or erratic idle and an SES light. That one may have a plug option to replace the breather, though. I recently bought this one for my brother's truck (I have a catchcans.com one that I'm happy with). It looks to be a well-designed unit, especially for the price, and the only thing I'd do to it is add a piece of stainless scrubber pad on top of that round silver disc. I did this to mine and it improved it's efficiency. I just wish that Amazon one had a larger capacity. But it's easy enough to drain with the valve. I also wish the inlet and outlet ports were swapped around. They have an identical model with 3 ports that has a second inlet port that I should've gotten. I would screw a plug into the other inlet and then the ports would be oriented in a better position for a cleaner look on our engines.
T
trailblazer
Here is an update. I think I’ve driven about 400 miles since I installed the oil can. I drained it and some nasty emulsion came out. I’d guess about three ounces. I was quite surprised that south water lurks in these engines. I need to install a miniature ball valve and drain hose at the bottom of the can.
St. Louis
The water is condensation formed inside the can
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
Drewphil
