Odd sensation on acceleration from full stop
jyi786
Vehicle: 2012 Yukon Denali XL. Awesome truck, about to hit 100K, no issues to speak of, except this.
When accelerating from a full stop, I get a very odd sensation. It feels like something on the driver's side front suspension/wheel "lags" behind the rest of the truck. Kind of like a thump, but not exactly a thump. It feels like when I hit the throttle, it kind of delays behind the rest of the truck before it starts moving, whereas the entire truck otherwise is already moving. It's definitely not the brakes, because I did a full brake job recently, and this precluded that job.
Definitely related is the fact when going over a bump with the front wheels cocked to the left, something underneath the truck (I believe front driver's side) makes an extremely loud "clank".
I believe it's suspension related, but have no idea where to start looking. Tie rods? Sway bar links? Strut? I'd rather not start throwing money at it until I have at least an idea.
you might get lucky and have it be something less complicated, check your motor mounts, sway bar bushings & end links, upper & lower control arms. you can check the motor mounts by raising the hood so you can see the engine from the drivers seat, put your foot on the brake, put it in gear and while holding the brake pedal firm give it some gas and observe the engine to see if it jumps or if it just slowly moves a bit, then do the same in reverse gear, if the engine just slaps from side to side then you probably have a bad motor mount/s
J
jyi786
Bolt-on parts in your driveway. I think it was @Doubeleive recently replaced his or at least contributed part numbers in another thread. IIRC, there are two and one is only available from the aftermarket.
Thanks for that. I tried doing a search and wasn't able to come up with anything. I did find a bunch of people having a very similar issue.
https://www.tahoeyukonforum.com/threads/07-suburban-front-end-noise.1375/
Paging @Doubeleive. I'd appreciate any suggestions!
you need to check what I mentioned above as well as the wheel hubs, struts and slip yoke, the front differential mounts are a last resort if everything else is good, there may be a way to get it up on a lift and stick a pry bar up in there and see if it has any abnormal play though.I just went ahead and had them done after checking everything else
J
jyi786
The thread didn't update before I replied. :D
I did already try the motor mount check. The engine barely moves at all (or very slowly/just a tiny bit which looks normal) when I tested for it, so I thought that wasn't it.
slow and little movement is normal
Do the simple stuff first. Check the swaybar end links, 4 rubber bushings on each side, 2 up, 2 down on each side.
camaroz2887
Nj
Cv axel? Any clicks on hard turns? My original cv went bad and it was just doin the normal click click click... however the Napa axel that I replaced literally today was just starting to have the same sensation on acceleration only from a stop:mad: but it was also accompanied by a slight audible thud and the normal clicking as well.
You seem to be feeling it not hearing it though so I dunno. It might be worth a look though.
Good luck
On a side note the sound dampening in these trucks is pretty far above what I expected (though that’s not hard). I went into winter with very light clicking of the cv and forgot about it til spring! First time the windows went down I almost cried for letting it go on that long.
J
jyi786
Good luck
No clicks. Just clanks when going over bumps and with the wheels cocked to the left.
Ok, so I went under the truck today. Still not sure what is causing it. I ordered new sway bar links, and am going to try to install them tomorrow. I identified and tightened up the bolts for the front differential mount, and it almost seems like it's clanking less, but I can't be sure until I drive it tomorrow.
Also, I'm a bit afraid now: I found what looks to be gear oil dripping out the rear end of the front differential, where it connects to the long transfer rod. What does that mean?
PG01
Up here to the right
Its just a seal, easy to replace....although if the seal is leaking maybe your front diff is starting to go out....common on awd models...depending on prior maintenance history....and that could be your clank.... fluid level could be low.... and that could be your clank... see where im going here?
front pinion seal, replacing just the seal may not be so difficult but if continues to leak after that then the problem is deeper
J
jyi786
Yes, I do. Since I bought the truck, I've driven 66K miles. It only started doing this recently. I've serviced the front diff twice since I got this truck; when I did it the first time, 2.75 qts. or so came out; same this time, so I don't think the clank is because fluid is low. It's definitely mechanical.
Yes, I'm getting consensus on this now. Pinion seal definitely.
I'm going to monitor it, and I'm also going to change the sway bar links tomorrow evening to see if it makes any difference.
wjburken
Eastern Iowa
My first thoughts were the front differential is going. I would not think that a bad seal would cause a clunking sound. A bad bearing or low fluid might, but likely not low fluid if you have just recently serviced it.
One thing that can tear up a front differential as well as a transfer case on an AWD vehicle is if the tires are not all the same circumference.
Just confirm that your front tires are the same size and have the same amount of wear as your rear tires. I’m sure yours are but I’ve seen people, even dealers, try and save money by only replacing two tires on an AWD vehicle and end up tearing up the drive train because they have brand new tires on the front and worn tires on the rear, or vice-a-versa.
J
jyi786
Thanks for the suggestion. I myself have read horror stories about people using tire and wheel sizes that end up wrecking their drivetrains.
I can unequivocally confirm that's not the case with me. The wheels are all the same size, tires the same as well. I bought them from Tirerack, had them installed professionally, and have them road force balanced religiously every 7500 miles as specified in the manual. All tires show wear evenly and do not show any evidence of irregular wear patterns.
This is what is so confusing to me, because I was sure if something was going bad suspension-wise, it would have manifested itself at least on the left front tire, especially as loud as the clanking is now.
I'm really, really hoping it's the sway bar links.
J
jyi786
Update: changed the sway bar links. Did not fix the issue. :( But the ride is considerably improved; the stock ones on there were completely trashed, dried out completely. It was like riding on stones. Front end doesn't jounce over bumps anymore and is completely smooth like glass when cruising.
I sent an email to my shop asking them how long and how much it would cost to change the diff mounts and the pinion seal.
JimG
I had a similar sensation in my 12 ESV last year. Turns out it was a collapsed engine mount for me. Fairly inexpensive correction.
Dh1280
