Good evening All, having an issue with my 2001 NBS 4x4 Tahoe. Stock.
So I'm trying to pass smog and was running into a 0161 and 0141 code (downstream sensor heater circuits for both sides). After some investigating, all o2 sensors are good, replaced and verified they work with multimeter. My problem is that the o2B fuse that controls downstream Bank 1 Sensor 2 and Bank 2 Sensor 2, keeps blowing. I have traced all the wires, nothing is burnt, chaffed, etc. All ground contacts look are clean and good to go.
When I use my test light on the fuse connection slots where the fuse plugs in the box, I only get a light for the right side, the left side no light at all. I know this has to be wrong because the o2A fuse next to it gets a light with tester on both sides/pins of the fuse when I prod it.
I have also noticed if I put a new 15amp fuse in the o2B, and turn the key to ignition, wait a few seconds, and start it. It won't blow right off the bat. But if i drive it a few miles and look, it's then blown.
Does anyone have any ideas what could be going on here? Been at it for 5 days and I'm about to give up.
