NORCAL SS Custom 2/3.5-4.5 for all 2wd 2015+ GM SUV
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Rear depemds on what springs gm used. Thereare 3 different rates used. Either wsy with spacer shpuld sit fine on xl or suburban. If ypu want to go full rear drop i would add in front drop struts
CMoore711
I have this kit with the front drop spindles rear end links/bump stop kit and will be installing soon on my ‘15 Yukon Denali XL 4WD. I’m after a 2”(1.75”)/3.5” drop. That being said how should I set up the rear? Use the 1” spacer keep OEM rubber spring isolators in or use the 5/8” heater hose?
yukonchief
For you gurus........ how do I know if I have the auto ride shocks? I have a 2017 Yukon SLT with out tow package. Also which kit would get the rear leveled if not slightly higher in the back...... I just don’t want the front higher then the rear if you know what I mean.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
if the rear has airlines to shocks you have autoride. My kit will be fine thats why rear is adjustable
yukonchief
Just checked and mine does not have air shocks..... so which kit do you offer for a 2017 Yukon to make it level or as close to level. I just don’t want the rear being lower then the front. Can you provide a link? Thanks
dbbd1
Tony,
I would a slightly stiffer ride. 2016 Yukon, non-autoride, no mrc.
Would this kit, Product Code: 201858, if I do a 2/3 drop, accomplish that?
I sometimes tow (a small 3500lb travel trailer), how do I add helper bags to the order?
Thanks, as always, you're very helpful.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Can you text me 415 519 2432 faster to reply then here
2Denalis
Any issues installing the Belltech spindles on your 4wd? I’m leary about using the Belltech spindles on my ‘16 Yukon XL Denali 4wd due to an issue I had on my ‘13 Silverado 4wd with interference between the axle shaft, upper ball joint nut, and wheel bearing bolt.
dbbd1
Yep, you would have to trim that upper ball joint stud.
2Denalis
I understand that the upper ball joint stud is trimmed and assume a half-nut is needed. Even then, how close is everything? Does anyone have pics of this spindle installation on a 4wd?
dbbd1
Dang, can't find it right now. I did see a video of the McGaughys spindle install somewhere...
It didn't look that bad though.
2Denalis
Installed the McGaughys spindles on my ‘13 Silverado. They use a stud and nut on the front of the spindle in lieu of the top wheel bearing bolt and countersink the flange for the upper ball joint nut. Belltech doesn’t do this which makes the clearance around the axle shaft very, very tight.
McGaughys ‘16 Yukon XL 4wd spindle kit requires changing the upper control arms.
CMoore711
I haven't installed the kit yet. But now I'm curious as this is the first I've heard of there being any clearance issues or modifications being made. I was under the impression the Belltech spindles were a pretty "bolt-on" swap for the stock spindles.
Korbin_A
