Norcal ss 3/5 kit
NORCAL SS
SUV SUSPENSION GURU
Another one finished
kit used
http://www.tbssowners.com/store/index.php?act=viewProd&productId=192
NathanJax
Vacation Nathan
Jax, Fl
looks good
KpMc07HOE
That's definitely the look I want. Any info on what's used to get that look?
---------- Post added at 04:34 AM ---------- Previous post was at 04:32 AM ----------
Never mind I see the link(missed it)
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
first post has a link to what was used.
ddubdb3
currently on a 2/4 drop on 26s but thinking i wanna do your 3/5 drop any fender work required?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
to do rear kit you will need more then just springs
http://www.tbssowners.com/store/index.php?act=viewProd&productId=184
if you use oem shocks the springs fall right out
if you dont do the endlinks swaybar points way down and truck sways a lot
also lower control trailing arm brackets needed or lower arms bind and will hit frame
you need the shock exteners and only the djm shock extenders work with the trailing arm relocators.
you need to cut bracket off frame and when you do that no more bumpstop to protect you so i include new bumpstops that attch to top of axle
also panhard bar to fix offset rear end I would get unless you dont mind pass side tire sticking out more then drivers.
RotaryMachineRx
Saskatoon, SK
What tire size are you running?? You shouldnt need fender work but you will need to modify your wheel well liner behind ur front bumper (just use a 2x4 and dent it in with the wheel); but I'm assuming you already have done this being on 26's with a 2/4 drop.
07Dro
New Jersey
Tony, I currently have your 2/4 kit on the truck right now...do you offer a upgrade kit if i wanted to go 4/5-6?? I believe all i would need is front spindles, 6" rear springs, lower control arms, and panhard bar...
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
so right now you have front belltech struts with no camber kit and the rear belltech sp shocks?
Merch619
