No more chrome!
Red_Raider
Derby, Kansas
So I got the ride prepped the other night for today. I painted all of the chrome accents I had left i.e. Front and rear bumper along with the chrome strip on the grill. I also painted the billet insert black.Now she looks like a Z71 model. I just need to get the black suburban valance.
NathanJax
Vacation Nathan
Jax, Fl
Looks good. How did you paint it?
To complete the z71 look you should get the z71 lower bumper with the round fog lights
NeverSatisfied
eBay Baller
Wichita, Kansas
I got my paintable grille on the way fixing to do what you just did to mine
Looks great btw
YukonXL04
The Riverboat
Arlington, TX
Looks awesome man. I'm going white and black as well. Truck looks sick.
Paint that hitch black though lol
Red_Raider
Red_Raider
Derby, Kansas
1. Wash the chrome bumper with soap and water. Wipe it down with wax and grease remover to remove any fingerprints or dust.
2. Use 36-grit sandpaper and a dual action sander on the entire bumper if the chrome is peeling, flaking or has large cracks. If the chrome is smooth and in good shape, use 80-grit sandpaper. Sand the entire chrome bumper until there are no shiny spots to
3. Wipe with wax and grease remover and then spray the entire bumper with self-etching primer. This type of primer grabs onto the metal, allowing later coats of primer and paint to stick to the chrome. Allow it to dry completely.
4. Spray regular automotive primer to the bumper, directly on top of the self-etching primer. Spray two thin coats, allowing each to dry completely before moving on.
5. Sand the primer lightly with 800-grit sand paper, keeping the paper wet while sanding. Sand the primer without reaching the chrome surface. If you sand through the primer, reapply the primer and sand again, repeating the former steps. Allow the bumper to dry completely.
6. Spray the paint on the bumper in light, even coats. Use four coats of paint, allowing each to dry completely before applying another coat.
7. Apply three clear coats to the painted bumper, allowing each coat to dry before applying another
That's my next mod. I probably go through RockAuto using the discount code.
---------- Post added at 08:24 PM ---------- Previous post was at 08:16 PM ----------
Thanks guys! The hitch is just plastidip from a previous failed experiment with just painting the plastics. I'll be pulling it off for sure though.
Neil Layne
Steel Neil
Lafayette, Louisiana
that looks fantastic man. it is becoming my favorite nbs tahoes. the only thing i would change is maybe a black outline around the front chevy emblem, that way you could see it and still get the effect of the whiteout look. thats just me though. looks perfect man
jomulk56
Resident Lurker
IN
Looks great! I just started getting stuff around to do mine too.
Red_Raider
Red_Raider
Derby, Kansas
Thanks! The bow tie is billet aluminum piece. I'm not sure if I have a steady enough hand to put a black outline around it.
Gzes
the drifting 2dr
Wichita tx
Take it off and tape up the inside then spray and you got outline
WHITEOUT
Dont Hate-Appreciate
Phoenix
1000x better color matched. Love your look-Little biased tho.
Now all it needs is some desert pin stripping to make it a legit off roader. :laughing1:
CKendrick
