NNBS Esky Shift Lever
zach2011
Platinum Member
They'll be non-functional unless you have a 6-speed which supports the manual shifting.
Thanks a LOT to w33m4n for this part number, I will be ordering this soon and the Denali/Escalade door panels afterwards, I have been wanting those for a good while now...But I am going to get the 2010+ ones with the new switches.
Ben
Ben
PCB, FL
No problem guys, and Zach is right they will be non functioning unless you have the 6 speed which most of us dont.
felixgun
Lafayette, LA
What's the difference between pre-2010 and '10+? I would love the door panels but the tan leather is slightly different in color it would annoy me I think. If I had all black I'd get it... I'm def getting this lever once I see an install process.
Ben
Ben
PCB, FL
I went with black because it will match the top of my dash which is black. That was my reasoning.
felixgun
Lafayette, LA
I'm DEFINITELY getting that black leather wrapped lever. Above post I made im talking about the door panels.
zach2011
Platinum Member
The 2010+ ones are mostly the same, but the switch panels have a new shape.
I'll probably never care about driving the Escalade once I get the leather door panels, shift level, and heated/woodgrain/power tilt Denali steering wheel...and then get an 09 with the 6-liter and 6-speed and put all my mods on it. :D
felixgun
Lafayette, LA
What colors your interior door? Mines black and tan. I wonder what the leather door parts in black leather would look since my dash and doors are two toned back/tan anyways...
I'm really looking forward to install pics!!! :popcorn:
Ben
Ben
PCB, FL
I think my interior is just like yours felix.
zach2011
Platinum Member
I want to see this black/tan combo. I've only seen brown/tan and never really liked it.
My interior is the black/tan variety. Once I see what all is involved in the swap I may do this and I'll post up pics...
zach2011
Platinum Member
I have seen the lever when my dad removed the steering column out of his 08 Denali, and it had 1 big Torx holding it in. But I am not sure if you have to remove the whole column like he did. You might be able to remove the trim around the back of the steering wheel and access it there without having to pull the column out.
felixgun
Lafayette, LA
Here's an iPhone cam pic of my interior.
zach2011
Platinum Member
Looks cool! I probably have seen it and assumed it was "cocoa" before, I've hardly ever been inside a GMT900 with tan interior.
JimZ
Florence, SC
[/QUOTE]
Thought I was missing something at first....My '11 Denali has the stitching on the back side of the gear select lever.
Ben
Ben
PCB, FL
It was a pain to rewire. Not a pain to replace.
JamesinAbilene
