mrb5314
- Joined
- Sep 19, 2016
- Posts
- 4
- Reaction score
- 1
Ok. I have an 04 Suburban Z71. It has 205k on it.
While my wife was driving, the trans disengaged. What I mean is there was nothing. The engine would run. You could shift the column shifter, but it would no longer engage. She was able to coast to the shoulder and leave it.
She left it sit for a little while, and restarted it. It re-engaged and she was able to pull a little further so she wasn't it as bad of a spot. It then disengaged again.
When I got there, about 10 min later, I was able to get it into 4wd high and drive to a parking lot. Then that was it.
It seemed if you left it sit for a bit, it would run then would disengage again.
I have a transmission guy looking at it. He explained it was the trans sucking up the fluid to the filter and clogging it causing the problem. He also said it was shot and needs a total rebuild. $1600 was the estimate.
My question is this (for those that read this far) - would a fluid and filter change fix the problem? It was due (over due actually) for one. It runs really well, except right now lol, otherwise. I can swap a junkyard trans in but we may be looking to trade it in in June possibly, so I don't want to put a huge amount of money into it if a fluid and filter change won't fix it.
I also have an 03 Yukon with 226k that is starting the 2/3 shift issue where it revs up between shifts. I might be able to fix one of them, but not both at this point.
