New fan clutch sounds like a 747
AN292
Thing is loud as hell, engaged at all RPM's during acceleration. Even louder than the old one
Should it just loosen up??
mattbta
Frisco, TX
What brand did you get? Reading reviews of aftermarket on Amazon, this was a common complaint. I went AC Delco and it's like factory.
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
When you installed it you should have been able to grab the fan and spin it easily. There may have been slight drag/resistance but should spin easily by hand. If you could not, that is a bad fan clutch. It sounds like is engaged all the time. It's like the heat that is supposed to activate that when the temp rises enough on the air coming in to it, is a constant heat instead of on and off. AC Delco is the way to go.
Sure would help if you put the rig(s) info in your account signature.
Mechanic421
06 Denali XL
Statesville North Carolina
From my experience they will pull hard cold for maybe 30 seconds then quit down. When temp comes up you will hear it working again. If it is loud cold all the time it is probably bad.
AN292
AN292
Sorry guys it’s a 2004 Tahoe LT
It’s Duralast from Autozone. Right after I made this thread I bought the ACDelco one. So I will update this thread in a few days. Thanks
tom3
Went through four of them on my old truck. Finally gave up and put an electric fan on it. Hard to believe the aftermarket can't make a decent fan clutch, and they aren't cheap.
robb.
dallas
had a new clutch installed like 8 yrs ago.. and it also makes that 747 sound.
felt like i was driving around in a big mack truck.
im thinkin about goin with E-fans.
dizhai
