need some info on gettin more out of my truck
darin95yuk
alright guys i need some info on getting more power and fuel economy i was just wondering on what gas miliage your rigs get and how many horses you guys got? mine is a stock motor 5.7 with a 6in rough country and 35s 3.73s yadayadayada i think im getting about 10 to 12? i was wondering on how to tune a pcm? and a cold air and headers... dont want to spend alot because i want to eventually go to a 6.0 and a 4l80e in my ride... just looking for something to help out for now...
I'm guessing by your 'name' that it's a 95?
Devious_Tahoe96
Mr. Budwieser
West Texas
Im getting 13-13.5 mpg, K&N intake, dual flowmaster muffler and exhaust, accel cap and dizzy cap. I do need to change out my wires and plugs. As far as wheels goes, im running 31" BFG KM's and i have stock 3.73 gears (soon to upgrade to 4.11's). I don't have a lead foot, so im babying the truck so i can get better mpg's especially the way gas is going....$3.65/gallon
raptorforme93
Tampa, Fl
I have a completely stock engine except for dual flowmasters and I get about 12 mpg and Im pretty heavy on the gas. Doesnt 96ProComp get like 16? Where is he at??
---------- Post added at 05:41 PM ---------- Previous post was at 05:40 PM ----------
And I'm running 33s with stock gears
19Yukon97
Texas
i have a stock motor. besides k&n filter and flowmaster exhaust. im easy on the gas unless i have to be hard... i get 13-14.5. thats mixed driving.
retorq
Kingman AZ
LOL @ 3.73s and 35s.
You can get more power out of it but you should adjust those gear/tire ratios to get it better.
Also with these TBI trucks you have one or the other, fuel economy or power. I did a Vortec head swap and am making alto more power, I'm using way more gas too.
96ProCompTahoe
IN
just filled up a couple hours ago on ($80 i'll never see again...) and averaged 15.99 miles out of the last tank :D
lifted, geared, headers, CIA, etc, etc, etc, hoping to get a couple more out of it when i get do the PCM swap/tune
darin95yuk
darin95yuk
i know the 6.0 isnt gonna help much but ill have more bang for my buck when it comes to balls... and they average 18 in my father in law 2004 suburban with a 6in lift and 37s... anyways how do i go about modding and tuning that stuff and what does it do? what is a cia and a pcm?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
CIA should actually be CAI or Cold air intake, PCM is Powertrain Control Module or engine/tranny computer.A CAI just involves changing you air intake assembly and ducting. PCM tuning involves evaluating variable about your vehicle systems and what you are looking to change to have your PCM reprogrammed.
96ProCompTahoe
IN
cai - cold air intake, sorry for the mispelling. pcm is the computer.
4.88's and procomp 35's (probably closer to 34's now haha)
Danny_Z56
Franklinville NY
I get around 15-16 mpg mixed driving.
If i get froggy with the throttle i get around 13-14mpg.
I'd say a good tune would help your mpg #'s.
A few things you could do to shed some weight are: If you don't go on long trips you could take out your spair tire and jack.Also if you don't use your A/C much you could delete the entire system.
A/C bypass pulley,
http://www.autozone.com/autozone/pa.../A-C-Compressor-Bypass-Pulley/_/N-jd17lZ91tb7
darin95yuk
darin95yuk
well thanks fellas!!! so how much does a tune cost to my computer and whats a good cold air intake? and where can i get it done? and with the lift kit my truck shifts wierd how can i have my shift points adjusted or can i? i like my 3.73s maybe i need 4.88s like 96s has?
retorq
Kingman AZ
I don't think Blackbear does 95s. 95s have chip in them tbichips.com is a good place to start.
darin95yuk
darin95yuk
is there a place to tune my 95? and is there a way to adjust my shift points? it only shifts wierd when im going up hill it will downshift to third then fourth then third and fourth i kind of have to feather the pedal to keep it in third all the way up the hill...
raptorforme93
Tampa, Fl
Someone with more knowledge will chime in but I'm going to say you definitely need to regear with those 35s on there. That will give him more power and should help or fix his shifting issue while going uphill shouldn't it?
Drewphil
