Need help troubleshooting A/C issue on 2010 Tahoe
AJ Moore
2010 Chevy Tahoe LTZ. I've recently been having some ac issues. AC blows cold only while riding mainly and the compressor kicks on and off. I've replaced the compressor, condenser, and accumulator. Still pretty much the same performance. Mostly warm while idling but doesn't always blow cold while riding either. If idling with a strong rev it will start to cool. Any ideas to what to look at next?
PPV12HOE
NC
I would check your fans at the radiator... low air flow will cause the pressure to spike and trip the limit switch... when your driving you are forcing air thru the condenser which is lowering the pressure...
AJ Moore
AJ Moore
That was my thought but my mechanic says the fans are operating properly
PPV12HOE
NC
Just because they are turning on and off doesn't mean they are working properly... it has to do with the amount of air they are moving...
What are your low and high pressure readings at idle with the AC on full power? Does the truck have any internal HVAC related codes?
Thar1918
I’m having the same issue with my 2012. I am thinking low and or high pressure switch. I don’t have gauges to verify pressure.
Where are the high and low pressure switches located?
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Did you do the orifice(s) when you replaced all those parts? What brand are all the parts? Add the correct recommended amount of oil when you did the parts? Did you flush the a/c system out while you had it apart? Did you check for any needed cleaning at the radiator when changed the condenser? Last but not least, it does sound like an air flow problem and the fact that the fans come on does not mean they are spinning at correct rpm when a/c is on. Very important for high and low pressure readings info when the problem occurs.
headala
Do you have the automatic thermostat air or the manual air controls? If automatic I believe there is something common with needing to clean out the little vent above the driver's head
Johnny1180
Johnny1180
Having same issue with my tahoe same year did you ever fix the issue
CKendrick
