My bagged 07 Yukon... pics & info...
08grey
Love the ride Nathan. Always top notch. Thanks for sharing the experience.
Blazed
Accepting Donations
The rear height is basically the same as before. What I fixed was moving my rear sway bar towards the passenger side like the directions say once you go so low. That was the biggest issue the first time. I still have the issue of wanting it lower, but you can really "fix" that without cutting and welding. If I cut the bump stop bracket off, I'll have to somehow weld the spring perch back on in order to bolt the bag back on. If I do that, why not do a mini notch in the rear at the same time. That's where I am at now...
At my set ride height, it's fine. Almost exactly like my static drop which was almost like OEM. I'm fine/happy with the way it rides now. Yes I still have the Belltech shocks, but I might try some OEM shocks if I can get my hands on some (cheap) to do a comparison.
No problem. That's why I started this thread and made sure I had all the different heights measured out. :Handshake:
Awesome work man thanks for all the replies looks great!
OHSIXX
Milwaukee
Hate it.....you should sell it!
J/K looks :boobs: or :jawdrop: or a little bit of both!!
iCalvin
California
For the rear, the back is as low as I can go without cutting stuff up. The upper spring perch is part of the rear bump stop bracket and is what the bag attaches to so I can't do the free travel mod. I've looked in to this a lot and found my definitive answer (before cutting mine) from this thread here in post 5
So you haven't done the free travel mod? I cut my brackets off this past summer and haven't had any problems (not saying there won't be though) but for the most part the spring perch is still welded onto the frame so cutting off the bracket doesn't mean the perch comes off with it. I have thought about welding the remaining bumpstop bracket to the frame but so far there hash't been any "bending out/in" of the actually perch.
The metal on the right side of the bump stop is what I am referring to, i basically cut and grinder away all of the bump stop bracket visible on the outside and left the inside "hidden" part alone. Lowered 4" inch in the back that is how much space I have till frame. The red bump stop is an inch tall for reference. I used use an angle grinder and removed the gas tank for safe measure.
Also, love your truck its awesome and bags just complete it.
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
Thanks for that pic. In the thread I mentioned, it looked like you had to cut it all off... I might be doing some cutting this week...
Ben
PCB, FL
glad to see you removed that ugly usc sticker
NORCAL SS
SUV SUSPENSION GURU
they are the ck375 wheels 24x10 i have them in my store section.
GalaxyBlackEsky
BlackedoutLT3
MD
Missed this thread.. But looks really good. I always wanted to do this kit and def thought I would have but. I just can't do it with our MD weather. Affraid I will mess up the air some how. So Static ride for me forever.
yates ™
Resident Apple hater
Iowa
What are your concerns with air suspension and the weather? The system runs an air dryer to virtually eliminate moisture from making it into the tank and if you are still concerned you can run a small amount of air break antifreeze or even a little bit of alcohol in the tank. Kelderman has 60% of the ambulance market which are in use from Canada to Florida and they run year round in any conditions.
yates ™
Iowa
Many vehicles including semis run air components, we actually adopted the air dryer technology from the semi world.
yates ™
Iowa
You're worrying about non-issues, now order a kit so you can quit wishing you had one lol.
GalaxyBlackEsky
BlackedoutLT3
MD
Well some BBK's are in first order. Which might be coming sooner then expected.
Young28
The Yukon God
ga
airbags will freeze up the second it thinks about getting cold. you should juice it.
dizhai
