mid-frame cut & extended?
JPcalaveras
Im starting to research for a mid frame extension of 2-3 inches to fit my 59 belvedere on top of a 2003 tahoe.
You can find a lot with the s10 frames...but the tahoes appear to be a bit different.
Cant find anything where someone has done it with a Tahoe...I'm not a pro with these search functions yet. Any links or photos much appreciated.
Thanks.
Thanks.
This should point you in the right direction:
Welcome to the Forum from NH.
bigdog9191999
sw michigan
first i think the project would be cool. with that i cant say i knew regular kits where out there for the s10, but it makes sense as they are a little more common chassis for custom swapping things ( rat rods ect. )
although it dont look like much more than some lightweight c channel and some fish plates. for me personally i would wonder if the longer suburban/avalanche/xl ect chassis would be a better fit, then it can be cut down and not have extensions (leaving one cut and seam instead of two) , not that it should really effect anything, but it makes me feel better. although you would still want the smaller tahoe size tank as you wont have room for the bigger tank of the longer wheelbase once cut down, unless your doing custom tank situation.
Alex_M
I'm doing this to an '86 Dodge truck that I'm swapping an extended cab onto. The route I went was to take a cut out frame section from another truck to splice into the middle of my existing frame. Weld it in place and then also plate over the welded together sections.
Not a project for a beginner welder though.
Candielaine
