Lowered or Lifted?
BlueTahoe2001
Charlotte, NC
OK,
Im looking at either going with a lifted look OR a Lowered Look.
Not sure which one I want to go with so just wanted to get some opinions and see what you guys think?
Also Heres what I was looking at wheel wise-
Lifted- American Racing Wheels BAJA- 16x8 on BFG's 265/75R16
Lowered- 20" 547 Vision Wheels on (Tires not sure on what though)
All opinions welcomed :Handshake:
3blackchevys
New Jersey
I like the way it sits lowered on your body style and mine
older models and 2 two doors, I really like lifted..just my opinion. If you lower it, a tire choice could be the Yokohama Parada Spec X.
Crazy Al
Mukilteo, WA
That's a small tire for a lifted rig...You could run that stock, I think you (correct me if I'm wrong) can run a 285/75R16 stock, maybe with a little trimming. If you go full on lift with a 4" or larger kit you should be running 33's or 35's. If you do f150 keys and spacers in the rear, you could still run 33's. 02TahoeMD has a rig setup that way.
BlueTahoe2001
BlueTahoe2001
Charlotte, NC
Should have clarified myself a little bit more- When I mean lifted look- Like Off-Road Tires/Rims and bumper ECT...
Thanks for all the suggestions guys. Doing a little bit of math now to see where I will be money wise if I go either way.
More opinions are welcome!
TheFuzz
Idiot Police
Spurbury, VT
I'm also running the setup that Al is describing. Ford keys up front, 1.5" coil spacers in the rear, with 285-75-16 Nitto Terra Grapplers. It does everything I need it to, and it looks great. Note: 285s will not fit very well in stock trim. At the very least, you need to crank your stock keys. I was still rubbing in the right rear until I put the spacers in.
Personally, I think that trucks like these shouldn't be running full-out lift kits. Keys and spacers gives you a beefier look and clearence to run 285s without looking retarded. I think 4"+ lifts on NBS tahoes and yukons looks kinda goofy, honestly...it suits the OBS trucks and SUVs much better IMO.
Here's my setup:
YNOT
i'm a lowered guy, i only like lifted trucks if there running 35's.....lol
tybardy
everyone needs a Hoe
Gilbert Arizona
i like both actually... lifted is a little harder to do IMO because its hard to make it look nice, if you go with that lift, i would run a bigger wheel though
thejstar
Hutto, Texas
i was gonna lift, then decided that since it was 2wd, that was a waste, so i am at stock ride height with 275/55/20 and i am happy for now. my bank account is too... when it is new tire time, i am going to 295/50's with a bit of inner fender "adjusting"...
BlackDenali
Roof Rack ****
Boca Raton, Florida
Origionally my truck had 285/50/20's and I lowered it with a 2/3 kit and I was happy for the moment ;) A week later I ordered my 24's and now I'm looking for a bigger drop! It's a never ending cycle! Good Luck!!!
withac
Eastern Idaho
Yes...Just that rugged off-road look with some aggressive tires.
The truck is a 4X4...
K, cuz IMHO, 2x4's shouldn't be lifted, not when you look at the actual reason for a lift. Just remember the more aggressive tires will get worse mileage and will be louder going down the highway. I have I think 265's on my '**, whatever is just one size up from stock. That helps the look I think. Once again, IMHO, if you're going to go for a lift, make it worth while, 33's are a nice size, much bigger than stock but not huge if you don't want that look. Just remember larger tires screw with your gear ratio if you plan on towing much.
cdhpc2
