Looking for ideas from sub box behind 3rd row seat 07 Tahoe
FINALTOUCHFRI
Florida
I'm looking for a serious box custom or not to go behind my 3rd row seat 07 Tahoe LTZ. I want it to hit hard. Any ideas or pics?
I have a custom, downward-firing sealed sub enclosure with an Audiomobile 10" sub between my 2nd row captain's chairs, but it is movable to anywhere in the truck. I power it with a 500 watt RMS Rockford Fosgate amp installed inside the truck's rear side panel. One of my dogs also uses it as a seat, when we are driving down the road (hence, all the dog hair).
I wish you the best of outcomes on your sub project.
FINALTOUCHFRI
FINALTOUCHFRI
Florida
Not bad, looking to put something custom behind third row that's going to hit REAL hard. I already have two amps installed under the second row seats. 1- 1K watt MONO Fosgate amp and 1-800 watt 4 channel Fosgate. Just haven't found the box box that hits yet. I may have to go to a local shop for a custom box. Just looking for ideas now. I want to be able to disconnect the box when I need to take the seats out.
When I installed my box, I wired to the amp with a trailer wiring plug. The style that you can unplug, for the times I needed to take it out.
If you have a 1KW monoblock amp, you may want to use a higher amperage connector for your speaker wires, to ensure that peak amperage output surges from the amplifier get to the sub with minimum resistance. I have used these high amperage connectors for many applications, and they are quite durable and compatible with thick electrical cables. I picked them up on Amazon.
Meccanoble
Georgia
you can get a shallow box that will fit behind 3rd row. I have a Hertz sub that hits even though its a bit shallow.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Here is a pic of my 3rd row box I built for my 09', Escalade not the greatest Ive done but it not bad.
2- 12" P3 and DC Audio 1.2K, Android 10.4 headunit
Gawd Damn!!!!!!! :cheers::chewie:
SOCALIGUY81
La Quinta, CA
I squeezed 2 15" CVRs behind the 3rd row in custom sealed boxes and it was perfect.
PS This is my Tahoe from the "2007+ Add Sub To Tahoe" sticky thread ; )
X-ray Nerd
