Looking for 2011 Chevrolet Tahoe repair manual
Nick Gateley
Is there a workshop service manual and or repair manual , I had a Mazda rx8 and found free access to a workshop manual only thing I’ve found is emanual asking 31$ with bad reviews ... I need to do some repairs on my 2011 Tahoe ltz 5.3L
Geotrash
Dave
Richmond, VA
I have a printed copy of the Haynes manual that I use and I also subscribe to the alldatadiy.com service for mine. I found a freebie collection of pdfs once but they were for the Escalade and while they're similar, dealing with the 50 pdfs was a PITA. In my opinion, you're better off with the alldatadiy subscription.
petethepug
Michael
SoCal
I ended up just buying the 5 volume OEM shop manual's on eBay they were pricy
This,
If you’re going to have your truck for a few years this is the way to go. There’s pics, diagrams and it’s beyond thorough. Getting a used set off eBay is the way or pick ‘em out even cheaper getting them one by one.
NoNamesLeft
SE Michigan
For future searchers, the factory manuals can still be purchased directly from Helm Inc. Some years are available on USB thumb drive or CD. The 2013 was only paper and was 5 large books. Cost as of 8/1/23 was $400. The shipping was a bit steep around $60, especially since their warehouse is about 3 miles from where I work, but they don't allow the manuals to be picked up.
j91z28d1
that's very cool. I had no idea. looks like 350$ for the 2011.
do you know if it has the gm Documents in them? like I have tsb that reference gm docs that I can't find in my work software or online.
if it had that, and since I have such a low volume model. it might be worth the money if something weird goes wrong.
NoNamesLeft
SE Michigan
If your question was toward me, no the paper manual does not include TSBs.
j91z28d1
hmm. yeah the documents and tsb's seem to be two different things. the tsb is usually online somewhere. the docs get referenced in the 3rd party manuals I have but I guess you can only get them at the dealer. I haven't stopped by to see if they will print them for public.
NoNamesLeft
SE Michigan
Looks like that operation charm might have the tsbs, but ain't nothing in this world is ever free or "no strings attached".....
Goldwing2000
This here is the holy grail of info.
Just wanted to say thanks for this. I'm just about to go change a motor mount and I thought I knew what I was doing but I looked up the page for the torque specs and the first thing on the page is this warning:
"Caution: When raising or supporting the engine for any reason, do not use a jack under the oil pan, any sheet metal, or the crankshaft pulley. Due to the small clearance between the oil pan and the oil pump screen, jacking against the oil pan may cause the pan to be bent against the pump screen. This will result in a damaged oil pickup unit."
I was totally going to jack it up by the oil pan.
solli5pack
I jacked mine up with a 2x4 on the cat converter. Others have had success with a block of wood on the back of the pil pan. Whatever you do make sure it's stable. Last thing you want is the jack to kick out when you messing with the mount.
Goldwing2000
I actually ended up putting a bottle jack with an extension under the oil pan rail. Maybe a little sketchy but worked like a charm.
buckwild27
EMT/First Responder Firefighter
Ohio
Have you found the Mitchell to be accurate? Have you ever used AllDatadiy and if so how is the Mitchell compared to AllDatadiy?
For anyone in the future that may have this question. I have not used Mitchell, but I found AllDatadiy to be correct and useful. I used it to identify the wiring differences between my 2014 Sierra and the 2020 yukon denali I got the front seats out of.
a1parrothead
