TheFuzz
Idiot Police
Liftgate exterior window switch replacement
Stopped by the local dealership and got a new exterior window switch for the liftgate. No idea how, but the previous owner managed to tear the button clean off so I have to use a pen to reach up in there and pop the glass. I have pulled the interior trim panel off of the liftgate, and I'm trying to unbolt the rear trim piece above the license plate (that the rear bowtie is attached to) so that I can gain access to the damn thing from the inside and throw the new switch in there. There are four 10mm nuts that hold the trim piece on (one of which is only accessible by removing the rear wiper motor...ugh).
Problem: the studs are spinning with the nuts, and nothing is loosening up. What gives here? Are these a one-time use thing that shear off and need to be replaced? It almost looks like the studs are made of plastic. I'm at a bit of a loss. I'd sure hate to run back to the dealership with the ass end of my truck all torn apart and say, "here, fix this"....but not sure what else to do.
Anyone have to replace one of these switches before?
For reference, here is the part number and the part I'm replacing:
Here is the piece I'm trying to remove - it's the small trim piece that the bowtie and license plate lamps are mounted to:
And why I'm replacing it..the old button is gone:
Any help would be much appreciated.
