Lifted/Leveled 2021 - Postem Up
Neima954
Changed some things up today. Went to the 2” level from RC (new release with front and back spacers). Also went up a tire size and squeezed in 285/55r22. Slight trim required to lower portion of front fender well behind felt, in-noticeable. Good luck going any bigger on a 2 or 2.5” level.
Is that the 2” front and 1” back or only 2” front? Also did it change ride quality at all? Thanks
BNKACCT
ATX
Got the 3.5 r/c kit in today. As well as the 33" nittos on 22x10 -25 hostiles.. wifes loving her new look!
BNKACCT
ATX
Do your front tires stick out more than the rear or am I seeing it wrong?
Certain angles it appears like that, since the front bumper tapers in on the z71. If you look down the side, tread showing is completely the same. I need to take some more pics.
CodyMaverick
Anyone running spacers? My new wheels are 0mm offset. With 305/55/20. I think I’ll have to run spacers to not hit the control arm.
DWSmoot
DWSmoot
Charleston, SC
Not sure why you would have an issue. I would check with the shop unless you are installing yourself. Stock offset is +28. I’m running +24 and do not need spacers.
CodyMaverick
Thanks. I thought it was -28. 0mm offset hopefully won’t be too pushed out.
Kory
Looks good. I have the same leveling kit that you originally had. My wife has been wanting wheels and tires since we bought it. I showed her the pictures of yours and she liked everything about it. I see that went to larger tires.
Do you still have the 285/50/22s? If so do you want to sell them?
TexasTZ71
I’m contemplating the Rough Country 6” with 20’s and the biggest tire I can fit. Stay tuned! I have a black on black 2021 Z. Just had a flip down dvd installed and tint done. Now for the outside!
Goggs7
Do you think you would be able to fit 35s with the 3.5 Rc kit? How does that set up effect the ride looking at doing the same thing to my wife’s z71. Looks great!
DWSmoot
DWSmoot
Charleston, SC
No sorry. Sold them.
Richard Hallmark
Pictures when it’s done. Also, did you look into biggest tire fitment?
Towmaster
