Leveled the 15 hoe this morning.
dageaux1209
With a little help from a buddy and 2 hours time I finally got her leveled out. I used the McGuaghy's 2" leveling kit. Pretty simple install for a drastic change in appearance. Here's a little before and after.
NathanJax
Vacation Nathan
Jax, Fl
Yes!!!
dageaux1209
dageaux1209
No auto ride on mine. From what I can tell the install isn't much different on the ones with auto ride though.
BMPNUGLS
Mid-MO
Gotcha. Was just curious what you did for the autoride links if you had them.
dageaux1209
dageaux1209
According to the instructions that came with the kit the linkage simply get bent to a specific dimension that they provide. They even have a diagram that is in the actual size to match up to.
omfs27
Looks sooo good. I need to do this. Is the install pretty straightforward? Did you do one wheel at a time? Or do you have a lift? Thanks for the help!
fire730
Louisiana
Looks sooo much better.
Any noticeable change in the ride quality at all?
dageaux1209
dageaux1209
The install is very straightforward. I did one side at a time due to not having a lift. Get a good floor jack and jack stands. That's all you really need. It's literally 6 bolts.
The ride quality hasn't changed much at all from what I can tell. I would suggest this to anyone who is looking for a better stance.
twhitechurch
Quick question, I have never lowered or lifted a truck. Is there a significant performance difference or is it mostly for looks? I understand it lower the center of gravity, but is it noticeable?
dageaux1209
dageaux1209
It's purely cosmetic but it makes it look far better in my opinion. Obviously lifted is more than just cosmetic as it provides better ground clearance when off road.
ROBELLO_103
what kit did you go with....... never mind edit: i read the whole original post haaha my bad
ERS2015
Looks awesome! I have the same kit in the box at home waiting to go on.
Mlstammerjr
