Left turn, no signal cancel
DSword
Wisconsin
Looking for a little advice on my 1999 Tahoe.
When taking a left turn, the turn signal does not cancel on it's own, most times. Some times, but rarely. Right turns are not a problem.
Is that a problem with the multifunction stalk or a some kind of rotating assembly trigger for the multifunction stalk?
I'll do the repair myself, but was hoping to avoid ordering the wrong or unnecessary parts. Thanks in advance!
Welcome to the Forum from NH.
Pics of the truck, please.
I believe that your model year uses a flasher unit for the directionals. I would suggesting replacing the flasher first, as it is readily accessible and is inexpensive. If this replacement does not resolve your issue, then I would suggest that the multifunction unit probably is the source of your issue.
adventurenali92
Big Bear Lake, ca
Check the wires going into the turn signal bulb socket on the back of the turn signal lense and make sure the wiring is not chafed or exposed. I had an exposed wire last year that would short out and then cause the right turn signal arrow in cluster and the LED arrow in my side view mirror to stay dimly lit and not turn off while driving. I replaced the multifunction stalk switch on my column and it didn’t solve the problem. Which is what led me to inspect wires.
AdrienR
