Kelderman air ride front alternative
D
djscrubb
Nosho47
Is that the lowest you can get with the aero sport bag? Are you running the stock shocks or using belltech sp shocks up front?
Sent from my XT1080 using Tapatalk
Nosho47
And how is the ride compared to it being static dropped? I currently have the avs front bag bracket with slam specialties re7's for the front and it is bouncy without shocks. That is why I'm debating whether to get the UAS bags or go with ekstensive front kit
kwb0748
165 psi up front.
Bags are the bigger not sports.
2 inche drop spindles in front. Tire sits about 3/8 inch from the fender liner in the front.
Ride is better than the static drop I had before.
I can go lower but need to tub the front before I do that.
yates ™
Resident Apple hater
Iowa
In the back if you use the shock extenders you should get another 0.5-1".
Nosho47
This is how my Tahoe sits but its with the avs front bag brackets and re7's... I may just go the same route and go with the UAS bags... Is it with belltech or stock shocks up front?
Xay2Smoove
