JL Audio - Stealthbox
ranorris2
The Coolest
McKinney, TX
Dont you have to chop up the console and lose all the storage space for the JL box?
B.G., i agree. I thought about buying the box and ebaying the sub so I could put in my choice.
No....it takes up no extra space, you wouldnt know its there until you turned on some music. It involves removing the Bose sub/enclosure if you have it and replacing with the Jl box
Sent from your boss's iPhone using Tapatalk
Nuttzzy
texas
i snapped this pic at a red-light.. i think its just a panel not the A/c vent so maybe i can have the console box.. ill check it in the daylight tomorrow and make sure
sorry double post dunno how to delete the 2nd sorry guys I'm retarded
Nuttzzy
texas
ok so i snapped a couple pics from both sides i still can't tell i have the A/c vents way up by the firewall.. i have the blower on the passenger side but there is still some space so i don't know if the console box will fit maybe you guys can check out these pics and let me know what ya think..
here is the passenger side you have the back of the bose box on the left and the blower housing i guess on the right
here is the drivers side after i removed the kick panel.. see the a/c vents on the left and bose box on the right. still quite a bit of room prob 6-8 inches from bose box to ac vents
here is my hand in there so give ya scale of about how much room.. but i dunno how big the MTX or Stealth box it..
ranorris2
The Coolest
McKinney, TX
Here is the install on the stealthbox (on jl's website): http://mediacdn.shopatron.com/media/mfg/9013/media_document/live_1/SB_GM_TAHOCNSL_MAN.pdf?1305783856
The website also says it will not fit trucks with AC Vents at the back of the center console...I dont think any of the nnbs tahoes have that but if they then they cant have the stealthbox. Other than that you should be good to go.
Nuttzzy
texas
I know this the ac vents are there but there is plenty of room. I went ahead and got on well see
L
logman17
Well guys and gals -
I decided to pull the trigger on the stealthbox in the original post.
It has the 2x10wO subs and mounts in the driver's rear window.
The amp they suggested is a JL Audio XD600/1 with a HD-LRC remote bass knob.
So that is what will happen here in the next week or so.
They did not stock the JL stealthbox so they had to order it; they said it would be here in a week or so.
So, all that being said, I should be able to report back to you all in the next week or two with some pics.
Thanks for all the help and feedback with this!
--Logan
L
logman17
Well guys, I got the Stealthbox installed,
looks great, sounds great.
Here is an installed pic for reference:
overall, it is great - a little loud for my tastes but the remote gain knob for the amplifier makes it real easy to adjust.
They removed the factory Bose sub (they thought there may be some phase-cancellation from the stock sub) and were able to mount the amplifier inside the console where the subs used to live.
Thanks for all the feedback that pushed me over the edge to purchase this equipment.
--Logan
Nuttzzy
texas
na no canceling i have that and the JL console sub..
Nuttzzy
texas
no sir i used two hifonics amps and the gm1416 for the plug and play something wasn't right had to end up going with a LOC instead of the harness then it all worked fine..
Denali0229
FL
How are you liking the subs? I think I might get the same one.
L
logman17
I love them, they hit hard and rebound fast so they are good for a lot of different music types.
The fact that I still have all the storage and can put the rear seats down if needed is a big plus!
--Logan
Nuttzzy
texas
I'm thinking bout selling the rear JL box just because i don't use it much and need some funds.. anyone in the houston area can hit me up about it if they want.. 07 NNBS in black
jo312915
"no sir i used two hifonics amps and the gm1416 for the plug and play something wasn't right had to end up going with a LOC instead of the harness then it all worked fine.."
What is the LOC? What wires did you tie into? Did you radio have the NAV/dvd etc. I am thinking of installing the console box.
dizhai
