intake option?
makindust2
Are there any other intakes that can be installed on a 1997 5.7 instead of the stock throttle body ?
It looks like an intake off an lt1 might fit
Thanks in Advance Skip
chaingun427
OBS Mad Scientist
Mooreland, OK
Big difference between the intake and the throttle body. The stock TB should be big enough to handle anything the stock intake and injectors can, you won't see much gain by swapping it out. If you go marine or ramjet intake you may want to go larger but again it depends on what you're trying to get out of it.
golavaman
